9-bolt Borg-Warner axle removal?
Old Sep 13, 2011 | 03:36 PM
t-topsavage's Avatar
Car: 1988 Camaro IROC-Z/28
Engine: L98 5.7L T.P.I, stroked 383
Transmission: turbo hydro-matic 700R4
Axle/Gears: Borg Warner 9 boltG80 2.77
I got my '88 Iroc-zs' *** in the air, rear differential cover on the ground driver side disc break all torn apart and I have to idea how to take the damn axle out. Its a 1988 Borg-Warner 9 bolt 2.77. All I need to know is how to remove the axle. Whats holding it in? Thank you
~Patrick
Old Sep 13, 2011 | 03:59 PM
hrspwr's Avatar
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
Re: 9-bolt Borg-Warner axle removal?
There are four bolts on the end of the axle that hold the retainers in. BW have c clip eliminators in them. Once you loosen those bolts your golden.
Old Sep 13, 2011 | 04:05 PM
Twin_Turbo's Avatar
Yup, take of the caliper and abutment, then the 4 retainer nuts on the "bolts" (more like studs w/ a flat plate on the back), then a couple of whacks w/ a mallet and the axle will come out.
dbrochard
Oct 3, 2015 12:43 PM
scottmoyer
Sep 7, 2015 07:06 PM
dbrochard
Sep 7, 2015 09:41 AM
rudolphschenker
Sep 4, 2015 02:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
