need help identifing 4th gen rear end
Car: 89 FORMULA 350 / 1991 RX7
Engine: 5.7 L98 / LT1
Transmission: 700R4 / 6 speed manual
Axle/Gears: 3.42 posi / 4.11 posi
ok guys i just got a rear end out of a car at the junk yard. the rpo sticker was long gone. I just could not it pass up. I need to determine the gear ratio. here are a few things that may or may not help. any help would be great thanks
1997 firebird 3800 engine
automatic trans
rear disc brakes
white sticker has a barcode, & 0625126
axle stamp on passenger side tube 7PS 6 2691
* The 6 could be the letter C
automatic trans
rear disc brakes
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: need help identifing 4th gen rear end
JamesC
Car: `86 SS / `87 SS
7PS is an axle code; PS used to be 2.41 posi in the 1970s; I think they are now 3 digits & refer to groupings of RPOs collectively (such as a 2.73 disc rear w/ traction control and limited slip would have a different axle code than a 2.73 disc rear w/ limited slip)
6 should be the assembly plant; could it be G? (used to mean Detroit)
269th day of the year; 1st (day) shift
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Just rotate the brake rotor, watch the pinion & count the rotations of each. That will tell you the gear ratio without having to open up the cover.
1992rs/ss
Jan 31, 2025 05:10 PM
hectre13
Dec 11, 2023 08:14 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
AkDrifted
Aug 17, 2015 07:45 PM
