How can I tell if my transmission is stock.
Car: 1988 Camaro, Holley 600 series.
Engine: 350 w/350 TPI heads
Transmission: 90+ 700R4
Axle/Gears: not sure
How would I go about finding if my transmission is stock. Is their a number that I can pull and a website I can decode it at? Is there a brand name on it somewhere, any help at all will be appreciated thank you.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: How can I tell if my transmission is stock.
Do you want to know if it's "stock", or do you want to know if it's "original"?
Original I guess. Or just what transmission is in it.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Car: `86 SS / `87 SS
There's a section in the User CP you can fill out:
If it's a T5, grab all information from the metal tag attached to the tailhousing and decal on the top of the trans. (may be possible with a mirror.)
700-R4 tends to have an ID tag rivet-attached with information, as well as some stampings in the case; sometimes on GM transmissions it's above the pan rail.
Post that up.
Transmission
What transmission you have.
Post that up.
Read this post: https://www.thirdgen.org/forums/tran...ttom-pics.html
Go down to where the guy says I have an electronic speedo housing from the year 90+. This is why I want to know what transmission I have because I think this is wierd. If you is right then I have a cable speedo, and an electronic speedo.
JamesC
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
