Wires haning from bottom (Pics)
Old Sep 15, 2011 | 11:47 AM
xxZ28xx's Avatar
Car: 1988 Camaro, Holley 600 series.
Engine: 350 w/350 TPI heads
Transmission: 90+ 700R4
Axle/Gears: not sure
Hi,
I found multiple wires haning from the bottom both of them are ripped and wires are showing. One is ripped in half im pretty sure their there for a reason so I was wandering if anyone could tell me what they were. Also my shifter I think is a little messed up. The rubber piece is broken and its being held on by zip ties so its a little wobbly. By shifter I mean the thing underneath the car its like a rod with a rubber shock on it. I was wandering if this was an urgent fix?
1st pic wires so is the 2nd. The third is where the one came out of, I cant find where the other one goes. If you look its to the right of the pic its a little blurry but you can still see where it came out of. There is also no where to put my speedo why is this and where should it go?
Thank you for the help!
Attached Thumbnails Wires haning from bottom (Pics)-uknownwire.jpg   Wires haning from bottom (Pics)-unkownwire2.jpg   Wires haning from bottom (Pics)-33448543245860439.jpg
Old Sep 15, 2011 | 12:00 PM
xxZ28xx's Avatar
Re: Wires haning from bottom (Pics)
If you need more pics tell me. I have pictures of the ends of the wires but I didnt post them. If you want I can. Im trying to get this car on the road as fast as possible. =D Thanks for all the help in advance.
Old Sep 15, 2011 | 02:35 PM
xxZ28xx's Avatar
Is there something wrong that no one can asnwer this?
Old Sep 15, 2011 | 03:22 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Ok I will be the first it looks like the transmission torque converter lockup wires and the third picture is the speedo housing for a electric speedo I think 90 up
Old Sep 15, 2011 | 04:15 PM
xxZ28xx's Avatar
Thats really weird then because I have a speedo cable and if your correct on that then I will also have a speedo wire. How is that even possible!? So whats a transmission tourque converter lockup wire, and how important is it? (im replacing either way just trying to learn about my car). One of the wires in the first pic is the one that goes into that houseing. Could this possible mean a newer trans was put in my car? If you read about my car I dont know how to find out my transmission lol. Its an 88 though so why it would have 90 ^ parts is wierd unless previous owner had something to do with it.
Old Sep 15, 2011 | 06:56 PM
antoine's Avatar
I know my 1988 camaro have cable driven speedo
Old Sep 15, 2011 | 08:19 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Does your speedo work??
I would think a Previous Owner somewhere along the line did some things to it.
IDK all the ECM // ECU stuff, maybe the wires have something to do with a buffer box-to-vss..????..
Our 700R4 doesn't have electric lock up, has been fine for 4 yrs of spring // summer driving. IDK if it's bad for it or not!!
Old Sep 15, 2011 | 11:38 PM
xxZ28xx's Avatar
any more info on this?
Old Sep 28, 2011 | 07:34 PM
greggbruce's Avatar
Car: 84 454 monte, 89 formula, 86 camaro
Engine: the bigger the better
Transmission: 700/4L60 in everything
Axle/Gears: wish they were all 4.10's or better
if you have a speedo cable, it's NOT hooked up to the trans, cuz it attaches right where the 3rd picture is, and someone has changed the trans to one that doesn't operate a cable. The 3rd pic is of an electronic speedo sender. I imagine the wires go to that. I also imagine your speedo doesn't work. If your car has a cable, you will need to remove the trans tail, the metal speedo reluctor ring and install speedo gears and speedo gear housing to drive the cable. Hope that helps
Old Sep 29, 2011 | 06:36 AM
xxZ28xx's Avatar
Thanks for the reply this makes perfect sense, its what I was thinking as soon as someone mentioned the electronic speedo sensor. So is there a chance they could have set something up that this electronic sensor actually works for my car?
I was going to follow the wires to where they lead maybe they have my car setup differently. When I first got it everything was rigged up, so I woudn't see why this would be any different haha. But then again it is a cable driven speedo so I don't even know how an electric one would work.
So whats the price range of the procedure your talking about? Would it be cheaper just to by a electronic cluster panel and do it that way? ( almost all my gauges don't work, This old school cluster panel is my favorite though). Im pretty much just asking alternatives. you can list them and I will research them for prices and all that.
Old Sep 29, 2011 | 08:03 AM
greggbruce's Avatar
if there is a cable down there, hook up a battery powered reversible drill to the cable itself as if it were a drillbit, the hit the trigger, see if the speedo works. Try both directions. If it does, yes you need someone to install speedo gears. You have to remove the driveshaft, undo the torque arm from the tail housing and remove the tail housing. It might even be easier if you pull the small crossmember to get a little more room, but not necessarily. The metal gears can be a **** to get off sometimes, -- you could hack saw through it a ways front to back, then smack it with a chisel to crack it, and then it will slide right off. Then you need all the nylon gear parts, the clip, the speedo housing and retainer from a donor trans, or go to
http://www.transmissioncenter.net/sp...FetdTAod6zRcrg
and buy the ones you think you need --- probably call them for help. The chart will get you close to the right ratio, but I have had it be wrong before. I use a GPS to verify speed and have extra gears of different teeth to fine tune the speedo.
I suppose it is possible someone has put in an electronic cluster -- but I imagine the wires would look added on instead of factory.
Dollar-wise, I would say it would be probably around the same cash to convert to an electronic cluster, but better to hang on to the mechanical speedo and get the gears because then the car is still original, and it's a lot less headache to make it that way then change what has already been designed by GM for that year.
Just my .02.....
what are the wire colors anyway? and year, make, model, engine size? I have wiring diagrams available to me.
Old Sep 29, 2011 | 11:06 PM
xxZ28xx's Avatar
I own the haynes manual so I have some wiring diagrams also. Although its kind of hard for me to understand. Im not to good with wiring diagrams but could learn lol. Its and 1988 camaro, not sure what kind. looks like a z28 was sold to me like that, title says sport coupe but that doesn't matter apparently, I don't have any badges on it either so Idk what it is. all I know is its a camaro and I'm happy with that. Especially for how good it sounds now that I did all this work to it... I figured out the engine is a 305 but it has 350 TPI heads in it thats all the further I went engine wise. Its an F car and the wire colors were purpler and green, and they were bright purple and green. They seem to be going somewhere there just cut in half so I was going to track them down to where they went see whats going on.
If you could help me with the wiring diagram that would help a lot to because there is wires that are not plugged into anything but they are supposed to be.
Old Oct 3, 2011 | 02:45 PM
greggbruce's Avatar
on 87,88,& 89 cars, they all show cable driven, speed sensor on backside of speedo head. My 86 that's here I can look at only has a cable. Have you tried the drill on the cable thingy??
The wires to the TCC (that plug into the LH middle of the trans) show to be tan/black, light blue, and purple -- is there anything plugged into the connector on the trans, just behind and slightly above the shift shaft??
Caspar
Jun 19, 2016 11:19 PM
Bert87
Aug 23, 2015 03:50 PM
1985chevydude
Aug 20, 2015 12:29 AM
Jk_Under
Aug 17, 2015 03:08 PM
1989formula5.7l
Aug 17, 2015 02:56 PM
