TH700R small orange spring
Old Sep 22, 2011 | 07:43 AM
Mumko's Avatar
Hello mates, I need a big help related to a small spring I found.
I own a 84 Vette whit TH700R tranny. I am trying to repair the gearbox and... When almost everything was Ok i found on the ground a small painted in orange spring. I did not realize where and wnen come from this spring. I am not sure if came from the gearbox but with this color must be from there.
I changed all the o-rings and clutches, I did not open the valves on the valve body (only change the joints and clean around) So I am sure it's not from the inside of the valve body.
There are 2 pictures of the spring.
Please help meee.
Thank you.
Attached Thumbnails TH700R small orange spring-spring-1.jpg   TH700R small orange spring-spring-2.jpg
Old Sep 22, 2011 | 11:43 PM
Pro Built Automatics's Avatar
Re: TH700R small orange spring
This spring goes under the front pump slide pin.
Old Sep 23, 2011 | 06:56 AM
Mumko's Avatar
Thank you so much. I saw where is come from.
Thank you again
god bless you.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
FormulasOnly
Sep 6, 2015 10:42 AM
SG91camaro
Sep 5, 2015 10:27 PM
