4L60E Trans.
Old Sep 24, 2011 | 06:58 PM
JAMES LOWE's Avatar
Car: 84 Z28 camaro
Engine: 383 stroker
Transmission: turbo 350
4L60E Trans.
I was wondering if a 4L60E trans out of a 1996 camaro work in a 1998? Will the pcm in the 98 work with the 96 trans?
Old Sep 24, 2011 | 08:52 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: 4L60E Trans.
If they are both 4l60E's I see no reason it wouldn't, if its a different trans though, you most likely will need a different PCM. But if this is a 3.8 car I'm almost certain its the same trans through all the years it had the 3.8
Old Sep 24, 2011 | 08:58 PM
JAMES LOWE's Avatar
Car: 84 Z28 camaro
Engine: 383 stroker
Re: 4L60E Trans.
They are both v8 cars the 96 LT1 & 98 LS1
Old Sep 24, 2011 | 09:10 PM
Engine: 3.8, 3.4
Re: 4L60E Trans.
Hmm, my educated guess would be that the transmission is still the same between the years and the PCM can probably run either year trans, I doubt it could run both engines though. And I am pretty sure the PCM on the 4th gens controls the engine and the trans, with no real way to separate the ECU from the trans controller. Hopefully someone who knows the 4th gens better chimes in with some better info for you.
Old Sep 24, 2011 | 09:31 PM
JAMES LOWE's Avatar
Car: 84 Z28 camaro
Engine: 383 stroker
Re: 4L60E Trans.
Thanks man, I'm trying to help a friend out before he buys the trans to make sure it will work. I was thinking the same thing u are saying.
Old Sep 24, 2011 | 11:05 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Re: 4L60E Trans.
The bellhousing on the ls1 4l60 e is different they sell a adapter kit for installing a newer tranny in a older motor,and the pcm for the lt1 is not the same as the ls1 pcm
Old Sep 24, 2011 | 11:14 PM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Re: 4L60E Trans.
In obvious terms, No it wont work. By the time you adapt it to work (If you can that is) you could of sold the one you have now and just plain out buy the one you need.
92projectcamaro
Dec 8, 2015 12:25 AM
Nervous2
Oct 8, 2015 10:53 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
LSXcamaro
LSX and LTX Parts
Sep 17, 2015 11:17 PM
IROCZ1989
Sep 4, 2015 11:54 AM
