flywheel help!
Old Sep 26, 2011 | 12:25 AM
Maroz2884's Avatar
Car: 1984 Z28 CAMARO
flywheel help!
So lets start by saying that my car is a 84 z28 5.0 HO.
it currently has a t-5 in it but just purchased a t-56 so im trying to do the swap ASAP.
I have read many forums and discussions regarding this swap but the more i read the more i begin to doubt the swap.
The T-56 is from a 97 z28.
So im asking all of you who have info on this, what exactly will I need...
what i was given is the tranny with bellhousing and flywheel
2 shifters.(one short and stock one)
pedals
clutch
i did not receive any wiring or anything so idk if i need any of that or what else i need. only wiring i have are the ones that came in my car so i assume everything will clip up right?
For crossmember i was told to use the t-5 one and modify the wholes for it. is this true? please i need answers.
thanks
Old Sep 26, 2011 | 03:50 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: flywheel help!
The first link posted in a reply in your last thread has a "what you'll need" list. It includes a reference to a flywheel for 2pc. seal engines which was also gone over in your last thread by Shadow Z. Your thread title mentions flywheel but you don't ask a question about them.
That site has a picture showing a crossmember bolted in that shows roughly where he T56 trans. mount is located compared to the crossmember bolt holes. The following might be what he meant about modifying the holes, but it's meant for installing a T56 that is both spaced further back (by bellhousing spacer) and running a different tailhousing and mount location:http://www.sallee-chevrolet.com/Borg.../bwt56pics.cfm
The T56 swap thread stickied at the top of this forum should be your next bit of reading.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
