9 bolt question
Old Sep 30, 2011 | 12:12 AM
rocin87's Avatar
Car: 1987 irocz camaro
Engine: 305 tpi
Transmission: 5 speed
9 bolt question
I have an 87 iroc z with 305 t5 and a 9 bolt rear with I believe 373 gears. shouldnt it have a posi? Only 1 wheel spins so??? would there be an option code to find out if its posi?
Old Sep 30, 2011 | 12:32 AM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Re: 9 bolt question
Its not 3.73s. Most likely its 3.27s or maybe 3.45s.
Check the rear for ''Posi Tags''. It will be on the lower left bolts of the cover. If not then just pop the cover, you will find out the gears and see if it does have posi and might be just worn out.
Old Sep 30, 2011 | 01:02 AM
rocin87's Avatar
Engine: 305 tpi
Re: 9 bolt question
it does have 2 tags on it but I couldnt read them, rusted too bad. why do you say its not 373s. it seems like its geared kinda low just because I go through gears fast
Old Sep 30, 2011 | 01:31 AM
rocin87's Avatar
Engine: 305 tpi
Re: 9 bolt question
I made out out 1 of the tags it says slip resistant diff. So then what is causing it not to work right? What parts do I need to fix it And thanks for the earlyer reply
Old Sep 30, 2011 | 01:51 AM
Carlos773's Avatar
Re: 9 bolt question
Well for one its not 3.73s since those are gears for a 10 bolt. Only thing close would be 3.70s. 3.70s 9 bolts are very rare and from my research are found in 85 and 86 years.
Most likely the cones are wored out. Check out this thread:
https://www.thirdgen.org/forums/faq-...now-about.html
Old Sep 30, 2011 | 10:52 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: 9 bolt question
I agree. There is test to check over in the tech articles and excellent write ups on the internal design. 9 bolts use 2 cones with a spring and gear setup to build friction to lock the carrier. Overtime cones wear (case where cones sit wear too) and slack happens and it doesn't build friction properly. It's moderate to easy job to check it yourself if you have tools.
10 bolts and 9 bolts parts aren't swapable. Different pumpkin sizes and internals.
84z96L31vortec
Aug 20, 2017 12:16 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
