T-5 master cylinder on T-56 tranny
Car: 1984 Z28 CAMARO
So i have mounted up my t56 on my 84 and made all the mods and am currently in the process of modding out my cross member. question is can i use the slave cylinder for my t-5 on this tranny or what can i do?my tranny did bot come with the slave cylinder for the t56. i just have he spacer.
Last edited by Maroz2884; Sep 28, 2011 at 11:10 PM. Reason: i meant slave cylinder for title..
Car: `86 SS / `87 SS
Re: T-5 master cylinder on T-56 tranny
Did the trans. come with the longer line that's necessary?
Best choice is to simply buy the pre-filled, pre-bled assy at the GM store and move on. In, done, out, down the road.
i just cut the hose from the slave cylinder and clipped an extension so it can reach the back?
I'm going to go with Post # 3 For-The-Win.
When you get all the details wrapped up and can drive the car with zero hydraulic problems, it's a lot better than having to bleed used parts, hope that your line extension doesn't leak etc. etc.
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
Car: 91 RS Convertible
Engine: LSA
Transmission: 6060
Axle/Gears: 373
Ok read post 3. Most of this stuff is new to me. I looked at a picture of the gm clutch master cylinder assembly. Then I looked at picture of the diamond clutch kit and having trouble seeing how stock kit integrates with it. Does the hose plug directly to the slave cylinder. Are these two compatible. It's for an ls3 t56 combo going in to my 91 Camaro.
The OP picked up an LT1 T56 with remove slave cylinder that attached to the outside of the bellhousing on 2 studs with a spacer.
You're dealing with the concentric slave cylinder which mounts around the maindrive input to the front adapter plate. This has a quick disconnect fitting.
The 2 master cylinders are basically the same. The rest differs.
Engine: LSA
Transmission: 6060
Axle/Gears: 373
does that master cylinder pictured have a quick disconnect that will work with my clutch setup
Yes. The end of the line attached to the master cylinder has a yellow storage seal over it. That male end fits into the anodized female fitting of the slave cylinder pictured.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
