Third gen pedal u-bolt
Old Oct 4, 2011 | 09:52 AM
ssor's Avatar
Hi guys!
I am doing a t-56 swap on my car and I was wondering if I can use "normal" bolt to fix the clutch and brake pedal to the firewall or if I absolutly need to use a u-bolt?
Thanks!
Old Oct 4, 2011 | 09:56 AM
JekyllandHyde's Avatar
Car: 87 Trans Am GTA
Re: Third gen pedal u-bolt
we used normal bolts on mine beacuse my setup did not come with a U-bolt. Works fine.
I wold suggest though that you make a backing plate for the firewal to keep it from flexing.
Old Oct 4, 2011 | 10:06 AM
A backing plate is not necessary if you have the 2 little braces that go from the pedal pivot bolt to the U-bolt.
Old Oct 4, 2011 | 10:41 AM
ssor's Avatar
ok thanks guys!
theshackle
Aug 31, 2015 10:47 AM
19irocz85
Aug 30, 2015 10:03 PM
redmaroz
Aug 16, 2015 11:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
