stupid 700R4's.....
Old Oct 4, 2011 | 08:38 PM
NoSloZ_1's Avatar
stupid 700R4's.....
i recently put a 700r4 in my truck and started it up and nothing... i put it in any gear and nothing happens. doesnt matter if i give it gas or not. the truck is up on jack stands so when i put it in gear, the tires should spin easily. it was a used trans so i didnt have high hopes but i dont know if i didnt hook something up or if the trans is just junk? its an earlier model year one. 85 i think. i didnt hook up the wires comming out of the case though. im not sure if they are for the torque converter lock up or what. i hate trans stuff!! fluid is brand new and nothing smelled burnt inside it. i pulled the pan when first put it in the truck. anyone have any ideas? is it related to those wires not being wired in or should i have gears without it?
Old Oct 4, 2011 | 08:54 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: stupid 700R4's.....
Is it full of fluid? the filter on the bottom??
hook up everything b4 you start it up.
And cleanup your mess when done.
Old Oct 4, 2011 | 08:56 PM
n1ffer's Avatar
Car: 1983 Crossfire Recaro T/A
Engine: 5.0L Crossfire
Transmission: Upgraded 700R4
Axle/Gears: 3:23
Did you hook up the TV cable?
Old Oct 4, 2011 | 09:01 PM
jonarotz's Avatar
Car: 91 Z28
pump...check the line pressure.
Old Oct 4, 2011 | 09:13 PM
NoSloZ_1's Avatar
it was full of fluid, tv cable was hooked up and filter was on it. the only thing un hooked was the wires the come out of the case on the drivers side.
Old Oct 4, 2011 | 09:43 PM
jonarotz's Avatar
Car: 91 Z28
It will go into gear with that connector unplugged. It is just for the convertor lockup.
Old Oct 4, 2011 | 09:44 PM
NoSloZ_1's Avatar
thats what i thought too. it didnt do **** though...
Old Oct 4, 2011 | 10:11 PM
HeavyThundar's Avatar
Car: 81' Z28, 87' Iroc Z28, 05' GMC Z71
Engine: LB9 - 305 TPI - 190 H.P.
Axle/Gears: G92 - 3.23
Are you sure the converter was splined all the way into the pump before you installed?
Old Oct 5, 2011 | 12:08 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Broken pump
Old Oct 5, 2011 | 12:28 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Gotta ask, but is the torque converter bolted to the flexplate? I know it sounds dumb but I've seen that happen before.
Old Oct 7, 2011 | 05:27 PM
NoSloZ_1's Avatar
yea it was bolted up. it was a pita actually because when we first bolted the case to the block we didnt line up the torque converter holes so we had to loosen up all the bolts and slide the trans back just a bit to get the pressure off enough to rotate the converter to line up the holes. im gonna try the other 700r4 i have laying around and see if its any better. this time im going to use the 6.0 flexplate and eliminate the crank spacer. hopefully it works. if i knew how to post pics or vids on here i would.
Old Oct 7, 2011 | 05:44 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You didn't have the drive tangs on the pump properly engaged in the torque converter then. When correctly installed there's about 3/8" of clearance between the torque converter fully seated and the flexplate.
loud91rs
Oct 5, 2015 10:05 PM
djmarch
Oct 2, 2015 10:41 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
