700R4 Lock Up Issue, No Voltage From Brake Switch
Old Oct 7, 2011 | 02:02 PM
IROCtheThird's Avatar
Car: '89 IROC-Z
Engine: LSx
Since I've owned the car the converter has never locked up, I recently had the trans rebuilt. When I got the car back they told me the new converter still wont lock and its because theres no power from the Purple line running from the brake switch to the TCC selenoid. But he also said that wiring isnt what they do and I'll have to fix it. How do I fix this? Any help is appreciated. Thanks.
James
Old Oct 8, 2011 | 07:51 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 700R4 Lock Up Issue, No Voltage From Brake Switch
How do I fix this?
Find out why
Get you test light out and see if you have 12V on one terminal at the brake switch.
and that the switch is adjusted correctly to close and let power through on the other terminal
when pedal is NOT depressed.
See
http://www.austinthirdgen.org/mkport...ine_wiring.gif
Not to be confused with the brake light switch which works the opposite way; switch closes when pedal is depressed
Old Oct 8, 2011 | 10:18 AM
Car: '89 IROC-Z
Engine: LSx
Well apparently I do have voltage coming from the switch. Problem is I have 12v going through whether or not the switch is open or closed. I dont have the vacumm line for the cruise control hooked up, does this affect the swithc at all or do I have a bad switch?
Old Oct 8, 2011 | 01:26 PM
Car: '89 IROC-Z
Engine: LSx
So I dont know what its issue was but I just took everything apart and put it back together, the switch started working and now lock-up works perfectly
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
89GTAOz
May 16, 2020 09:31 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
