T56 Magnum Question
Old Oct 9, 2011 | 01:21 PM
porkenstein's Avatar
Car: 91 RS Convertible
Engine: LSA
Transmission: 6060
Axle/Gears: 373
T56 Magnum Question
I bought a T56 Magnum from D&D but now have a question. The part number is Tuet 7477 and says it's for a ls1, small block, and big block. On Tremecs site it shows that they are different transmissions for the older and the ls1 which is what I would have expected. Anyone dealt with this before so I know which engine this is actually for. I guess I need to call D&D or Tremec in the morning but I figured someone here has already dealt with this. Thanks in advance
Old Oct 9, 2011 | 02:51 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: T56 Magnum Question
An LS1 input can be adapted to SB and BB with a plate and an old style bellhousing. Hence the "fits all" description.
Yours is an LS style front with 2.66 first, .63 sixth. Keep your 91 bellhousing, hydraulic and clutch/flywheel, buy an adapter plate, measure the input so you can go w/ the correct pilot and bolt it up.
Old Oct 9, 2011 | 03:04 PM
Engine: LSA
Transmission: 6060
Axle/Gears: 373
Want to be sure I understand. If I use this with an ls1 in my 91 camaro I would just get a regular ls1 bell housing. If I use with something like a ramjet 350 or lt1 then I need an adapter plate with correct pilot bushing. Is that correct? Also can you tell me who makes the adapter plate?
Old Oct 9, 2011 | 05:36 PM
jmd's Avatar
jmd
Yes.
Yes.
McLeod and others.
http://www.summitracing.com/search/P...sion-Adapters/
The adapter plate was used originally(?) used with an extra long input to adapt the "aftermarket" Borg Warner T56 to a traditional (including 3rd gen) bellhousing.
Old Oct 9, 2011 | 06:53 PM
Engine: LSA
Transmission: 6060
Axle/Gears: 373
Thanks so much for clearing that up. I am kind of a newbie to doing this stuff and have allot to learn. This is such a great forum that that!! If I don't mind spending a more would I be better off with a new bellhousing instead of the adapter plate to my old bell housing or is that just a waste of money.
Old Oct 9, 2011 | 07:32 PM
92 BBC Z's Avatar
Car: Currently have 3 cars and 1 truck.
Engine: 1970&92 Cams,both BBC's
Transmission: LS1 T-56 & PG w/vendor's
Axle/Gears: Built 10 bolt& 9inch w/spool
If you dont mind speending a little money, then Quick Time is worth a look. They make a bellhousing for most every T-56 swap(LT1,LS1,SBC,BBC,V-10's even Porsche tranny's), and the quality is #10 on a scale of 1-10. Its what I use for my MkIIV BBC/LS1 type and didnt requier an adapter plate(but comes with a steel scatter shield), it even made up for the added length of the LS1 input shaft without needing special pilot bearing. I use a needle bearing type but only because it has more of a tapered edge, that makes it easier to stab the tranny. They cost about $450-550. which is a little pricey for something with no moving parts, but well worth it, in my humble opinion.
Old Oct 9, 2011 | 07:42 PM
Engine: LSA
Transmission: 6060
Axle/Gears: 373
Going to have so much in to it a little more doesn't matter. I like the idea of a scatter shield which is a necessity if I start racing. Raced back in the late 60's and love it. Not up on much of anything anymore so it's a re-learning experience.
beastin91rs
Oct 9, 2015 07:38 AM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
