700R4 problem. Always in first gear. Dude inside with Valve Body with pic!
Old Oct 11, 2011 | 02:43 PM
SpaniardV6's Avatar
Hello guys,
I recently replaced the governor, filter and gearbox oil gearbox. But the car still does not change gear. It works only first gear and reverse.
Yesterday, before mounting the oil filter and fill the liquid, I could see that a cylinder of the "throttle valve" is slightly down with respect to the other cylinders.
Could it be that the change does not work 1 st to 2 nd because the spring is broken and therefore the cylinder that is buried?. Is this drawing would be correct?. What I painted green, represents the cylinders. Sorry, forgot to take a picture.
I have another question, if my "throttle valve" is broken, could you put a "throttle valve manual" that makes my gearbox to the typical "1,2,3,4, D, N, R, P?.
I have read many topics on "manual throttle valve." Could this fix my problem?.
Thanks guys.
Old Oct 12, 2011 | 08:27 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 700R4 problem. Always in first gear. Dude inside with Valve Body with pic!
Looking at a diagram of the VB it appears that that is the issue. The 1-2 sleeve should be up against the roll pin.
RBob.
junkcltr
Aug 2, 2019 11:12 PM
jklein337
Sep 19, 2018 06:23 PM
lakeffect2
Aug 23, 2015 08:44 AM
TreDeClaw
Aug 14, 2015 06:58 PM
