TransmissionCenter Out of stock
Car: 1989 Formula, 1988 Camaro
Engine: Vortec 350 TPI, 2.8 V6
Transmission: 700r4, 700r4
Axle/Gears: 4th Gen 3.43 Posi, 3.43 Open
hey so i swapped my rearend from a 2.73 to a 3.42, i know i need the yellow 41 tooth driven gear and the 15 tooth drive gear, my tires are 245/50/16
so now the problem is http://www.transmissioncenter.net/sp...n_______va.htm is out of stock on the yellow 41 tooth drive gear, they do however have the 42 tooth drive gear in stock
how off will my speedometer be if i get the 42 tooth gear? like 2 mph or will it be worse?
and also my speedo is electric but it will use the same gears as the cable driven ones right? thanks
Car: `86 SS / `87 SS
Re: TransmissionCenter Out of stock
http://www.transmissioncenter.net/sp...__va.htm#700r4 has pictures of the gears for cable driven
http://www.transmissioncenter.net/sp...0gear%20driven has pictures of the gears for VSS
BTW, a lot of gear selections on websites and speedo calculators are different than what GM used. I've always had dead-on results w/ the GM gear selections. I'd err to the 42 myself.
ok im ordering it today, going with the 42,15 setup
Genopsyde
Oct 7, 2015 08:35 PM
