will a sticky caliper cause your 700r4 to surge?
Car: 1992 Pontiac Firebird Convertible
Engine: 5.0 TBI
My engine surges upon acceleration and while in overdrive, kinda like my torque converter in locking in and out so I wonder if my sticking caliper is causing this?? Let me know thanks guys
Engine: 5.0 TBI
Engine: 4++,350 & 305 CIs
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: will a sticky caliper cause your 700r4 to surge?
You're not applying the brakes when it's surging.
Engine: 5.0 TBI
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I think the ECM goes by the switch that's under the dash. The same one that turns on the brake lights.
Engine: 383 Carb
Transmission: 4L60
The ECM doesn't have the first clue whether the brakes are on or off.
TCC power is supplied through the switch on the brake pedal. Unless it's the pedal that's sticking, there's no way a brake problem can cause a TCC issue.
Car: 87 Camaro
The signal to lock and unlock the tcc is an electronic one that's sent when you press the pedal IIRC
Engine: 383 Carb
Transmission: 4L60
There's no "signal". The TCC solenoid is deenergized directly by the brake pedal switch.
the_hamturdler
Sep 30, 2015 12:50 PM
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
