12 BOLT HOUSING
Car: 92 camaro R.S.
Engine: 406 Carbed
Transmission: T-400
Axle/Gears: 3.73 limited slip
12 BOLT HOUSING
Hey guys, does anyone know which manufacturer sells a Bare 12 Bolt GM housing designed for Third Gen 82-92 Camaro/Firebird, I need it to be a direct bolt in and to accept my Sphon torque arm assembly, please point me in the right direction Guys, thanks...
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 12 BOLT HOUSING
moser and strange are the only people who make them AFAIK, you would probably have to call them or a dealer and order just the bare housing
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
Re: 12 BOLT HOUSING
Strange Engineering. I live right down the street from them.
http://www.strangeengineering.net/
Page 77-78 of their online catalog. I've been there 5 times at least and they're great people.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 12 BOLT HOUSING
I'm not sure about a bare housing. Usually it will be part of a package which would include axles and maybe caliper mounts like in the above picture. Not everyone wants gears and carrier since they may already have what they want to install.
If you already have a spool, posi etc, just make sure you know the spline count before ordering the housing and axles. OEM 12 bolt spline count is 30. The axles should come with 5 x 4-3/4 bolt pattern for GM but if you have some ford rims that you wanted to use, you would need to get the 5 x 4-1/2 bolt pattern. This would also need a rotor or brake drum with the ford bolt pattern. You could also upgrade the wheel studs to 5/8" drive studs if you're making enough power to need them.
Car: 92 camaro R.S.
Engine: 406 Carbed
Transmission: T-400
Re: 12 BOLT HOUSING
Wow, this is why I appreciate this Site, quick well informed responses, thank you guys, and AlkyIROC this is exactly the case, I have a series 4 unit and factory 30 spline axels, so I figured I'd just upgrade from the factory rear, again thank you Guys!
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
New2Chevy
Sep 28, 2015 12:35 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
