highest ring an pinion ratio
Old Oct 22, 2011 | 04:39 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
what is the highest ring an pinion ratio (gears) that can be put into the borg warner 9 bolt rear end i was told that 4.10's wont work in the 9 bolt i have 370's setup now but looking to get a better launch when the t56 is getting swapped in in advance
Old Oct 22, 2011 | 04:59 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Re: highest ring an pinion ratio
4.11's www.9bolt.com
Old Oct 22, 2011 | 11:51 PM
Engine: LR4 4.8
Originally Posted by Mkos1980
this is great info u sent me ive got one more question i seen a vid of a third gen restore an the guy put a dana rear end outta a c4 corvette im actually grabing a set of 113 heads off a guy with 91 corvette an he is also parting out the whole car what would i have to do to make this rear end work an also is it alot better then the 9 bolt borg warner rear end
Old Oct 23, 2011 | 09:15 PM
Engine: LR4 4.8
http://youtu.be/XfCnC395gOY in this vid off of youtube this guy is restoring a 1986 5.3 ls motor he talks about a dana 44 rear end that is a direct bolt on and it is alot stronger then the poop ten bolts that came in the trans am an camaros where can i find this rear end what car would have this ???
Old Oct 23, 2011 | 11:24 PM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
Dana 44's are extremely rare and came in firehawks. Go with a 9", 12 bolt or S60.
Old Oct 24, 2011 | 11:19 PM
Engine: LR4 4.8
Do they make these rear ends all direct bolt ins not that great at cutting an fabbing body work wish I was but one day I'll learn to master it :-)
InfernalVortex
Apr 20, 2021 11:31 AM
LT1Formula
Oct 8, 2015 08:34 PM
gord327
Oct 3, 2015 01:25 PM
FormulasOnly
Oct 2, 2015 05:52 PM
gord327
Sep 29, 2015 10:18 PM
