rear end is about to go out and need help
Old Oct 25, 2011 | 04:59 PM
TransAmSteve's Avatar
Car: 91' Trans Am 1le
Hey guys I have a '91 Trans Am with the 1le package I had the rear more or less go out on me the other day. Its making a high pitched whining sound really bad even after I pulled the diff cover, cleaned everything out, and refilled it with fluid. I've decided that I'm just gonna replace everything in it. I know I want to put 3.73 gears in it when I rebuild it as well. But I need to know what I'm looking for with the limited slip/posi set up.
I pulled the RPO codes that I have for the car and with the rear end it says I have.
G80-axle, rear, positraction, limited slip positraction l/slip r/axle
G92- axle, rear, performance ratio (merchandising option) performance r/axle ratio
GU6- axle, rear, 3.42 ratio 3.42r
Sorry if it doesn't make sense but that's the way its printed on the sheet. Anyways is there something in particular I should be looking for when trying to locate a new diff? And are there are there any particular models that I should keep an eye out for that would have these rear end parts? I'm probably going to have to get the parts used cause I don't have a lot of money at the moment. Honestly I'm not to familiar with rear end parts and this is the first time I'd be taking one apart so any help in locating or giving me knowledge as to what I need is greatly appreciated.
Thanks,
Steve
Old Oct 27, 2011 | 09:21 AM
Re: rear end is about to go out and need help
Also I know a 4th gen limited slip will fit, but would there be any benifits if I were to swap on of these set ups into my car? Or I know of a Iroc thats in a jy and been there for while that I think still has a rear in it would I be better off going that route?
Old Oct 27, 2011 | 11:45 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You might check the FAQ below for info that may (or may not) answer a few of your questions--or at least provide food for thought:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Oct 27, 2011 | 02:24 PM
guitarguy92b's Avatar
Car: 87 ws6 trans am
Engine: 305sbc
i would go in the rout of the iroc, its gonna be cheaper, we just picked up a complete rear end for my buddies z28 out of a jy for 150
Old Oct 27, 2011 | 02:52 PM
Hey James yeah I was checking that out earlier and I saw where you mentioned the G80 rear that I apparently have. What exactly is it that made it a more expensive option? How hard are they to find and how can I tell if a car in the jy has one? Guitarguy I think thats probably the route I'm gonna have to go I just have to find a truck to go down there with and pick it up.
Thanks for the in put guys
-Steve
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
