Stays in 1st at full Throttle
Old Oct 30, 2011 | 12:29 PM
JP007's Avatar
Car: 89 Formula
Axle/Gears: 9 Bolt 3.27
A GM mechanic rebuilt the 700R4 in my Formula which previously had the Transgo SK700 kit in it prior to the rebuild. They put back to stock with rebuilt valve body and does drive very well. But at full throttle it stays in first gear until you let off the pedal. It was at 6k and still didn't shift. I was wondering if they didn't replace the governor spring with a new stock spring. It shifts nice as they did do the Transgo Jr kit while doing the rebuild.
Also I did put in manual first gear and got the rpm up to 2500 and put it into 2nd gear and it still stayed in 1st gear even when I let off the pedal. Thoughts.
Old Oct 31, 2011 | 09:17 AM
VORTECCADDY's Avatar
Engine: 383 Superchared
Transmission: 700r4 built
Re: Stays in 1st at full Throttle
Is TV cable adjusted properly?
Ghettobird52
Jul 5, 2024 11:18 PM
theshackle
Sep 17, 2020 08:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
FreeSpirit
Aug 29, 2015 05:47 PM
novaderrik
Aug 10, 2015 12:44 PM
