Having an issue with my clutch.
Old Nov 4, 2011 | 09:29 AM
Slayerx666's Avatar
Put the carbed 350 in, with a flywheel and clutch set up for a Camaro, and couldn't bleed the clutch (no matter how much I bled I got no pedal). So I dropped it off at a mechanic, they tried pressure bleeding it, no luck. They're telling me the fork won't move, not even a little? So now I have to go get the car, and I have no idea what to do next. Any ideas?
Old Nov 4, 2011 | 09:48 AM
Slayerx666's Avatar
Re: Having an issue with my clutch.
All I did was put the linkage in it, cause it fell out when it had no motor.
The car is a 91 rs,!It's a carbed 350 with a clutch and flywheel from an earlier third gen (so the rear main seal would work) and the t5 and master and slave are all original from the 91.
Old Nov 6, 2011 | 12:47 PM
Slayerx666's Avatar
No one has any insight on why this might be happening?
Old Nov 6, 2011 | 03:20 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
It sounds like you have all the right parts.
User sofakingdom will soon be here to tell you the fork AND fork clip go in the same groove on the throwout bearing; the clip doesn't go behind the TO brg. sleeve. If you go check that before he gets here, it's a less painful experience for all of us.
Thanks.
Old Nov 7, 2011 | 01:17 PM
Slayerx666's Avatar
I'm pretty sure that's how it went together. The correct way
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
tonys91rs
Sep 2, 2015 07:07 PM
