Shifting way too soon... sometimes...
Old Nov 6, 2011 | 08:47 PM
91specialk's Avatar
Car: '91 Formula
Engine: 305 TBI
Transmission: Newly rebuilt 700R4
Sometimes transmission will shift into 3rd between 10 and 15 mph. I have to let off the gas then step on it to get it back to 2nd (or manually shift it). It only happens when the engine is at operating temp. Some days it does it a few times in a row (stop light after stop light) and other days only once, if ever. It shifts so fast it's like 1st.......2nd3rd.
Also will shift into OD by 25 MPH if i don't keep it in D. (this happens all the time)
I've adjusted the T.V. cable and that didn't make any difference. No codes come up either.
I've spent literally hours searching for this problem but have only found the opposite... "Shifting too late".
Anything will help, Thanks
Old Nov 6, 2011 | 10:09 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Re: Shifting way too soon... sometimes...
did u adjust the tv cable correctly ??? i would check there first its a cable on the throttle body that has a button have someone go wot while pushing the button in you will see the cable move out
Old Nov 6, 2011 | 10:13 PM
91specialk's Avatar
Car: '91 Formula
Engine: 305 TBI
will try that. Thanks
Old Nov 9, 2011 | 07:00 AM
Pat Hall's Avatar
If it doesn't end up being a problem with the adjustment of the TV cable, the only other thing I could think of to cause that problem would be the governor assembly. The governor is behind a round cover on the driver's side, tailshaft area of the trans. 99 times out of 100 it's the TV cable though.
Old Jun 6, 2013 | 08:43 PM
91specialk's Avatar
Car: '91 Formula
Engine: 305 TBI
Couldn't find the problem. Just got a rebuilt 700R4. That fixed it. I guess when in doubt... replace the whole thing. LOL!
Thanks for the advice though, I appreciate it!
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
