T-56 questions
Old Jun 6, 2013 | 06:54 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
T-56 questions
Hey everyone I am just having some trouble finding an answer to my question maybe you all can help me out.
I have searched!
I am in the process of getting all the parts I need for my t56 swap.
I am going to be putting the t56 in my 87 iroc that has the 700r4 in it now.
Can I use my 700r4 torque arm mount on my t56 ( lt1 style ) ? My t56 did not come with one? if not I believe this is what I need ( http://www.nookandtranny.com/mm5/mer...Category_Code=)
I still can no find a staight answer about what I have to do with the electronics?
so everything would work 100%
I know alot of people have used the dakota digital sgi5c box but what I have found out that it is only works if I have an electonic speedo. But since mine is 87 I have a mechanical speedo.
should I buy this ?
http://www.dakotadigital.com/index.c...rod/prd886.htm
Thank you for the help tgo!
Old Jun 6, 2013 | 08:11 AM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Axle/Gears: BW 9-bolt 3.27 posi
Re: T-56 questions
If it's the same as the T5, the torque arm mount is different than the 700R4. The difference is in how it mounts to the transmission. When I swapped from 700R4 to T5, I bought a used mount. I don't know if this is true for every case, but my torque arm faced in the opposite direction to the way the mount was shaped, so I had to buy new "rubber" for it.
Thanks for the heads up on that site.
I don't know much about T56, but that box looks like it should work.
Old Jun 6, 2013 | 08:39 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: T-56 questions
You can not use the mount from the 700R4... You can reuse the bushing if I recall correctly, but the mount is different and won't fit. That held me up when I was doing my swap. I had to wait on a mount from a T-5.
Old Jun 6, 2013 | 10:39 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Re: T-56 questions
Anyone got the mount for sale?
Old Jun 6, 2013 | 10:41 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: T-56 questions
For a cable-drive speedometer car, you can have member alloy here mod it so it has speedometer cable and vss functionality.
If you're going to run a cable anyway, that keeps all your options open.
Swap to a later model setup and need VSS signal? Use the VSS on the trans.; leave the cable in place.
Old Jun 6, 2013 | 10:53 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Re: T-56 questions
I've thought about alloys mod. I just don't know if I want to do that incase I decide to swap go autometer gauges later on .
I am thinking the edc box is a decent route. And its the cheapest too...
Old Jun 6, 2013 | 05:13 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Re: T-56 questions
Is the rubber/ poly bushing the same or is that different too?
Old Jun 6, 2013 | 08:31 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: T-56 questions
The same. I kept my Poly bushing.
Old Jun 6, 2013 | 09:10 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Re: T-56 questions
Thank you.
Bubbajones_ya
Aug 31, 2015 12:02 PM
Hello, Michael
Aug 20, 2015 03:19 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
cRoe4
Aug 7, 2015 08:46 PM
