Dana 44 ring & pinion question
Old Nov 11, 2011 | 05:08 PM
sparky8131's Avatar
I have a 87 IROC Z with a Dana 44 rear end. Does the 10 bolt 8.5" ring & pinion gears work in these? What about the ring & pinion install kit?
TIA,
Curtis
Old Nov 11, 2011 | 05:20 PM
Re: Dana 44 ring & pinion question
No.
No.
Be REAL sure it's a Dana 44 before ordering anything, since that reare never came in that car and was only available as an over-the-counter service replacement; and there are VERY few of those in existence. Specifically, be sure it's not a Borg-Warner 9-bolt, which is one of the 2 more likely things it would be, the other being the 7½" 10-bolt..
Old Nov 11, 2011 | 05:31 PM
sparky8131's Avatar
Cover does have 10 bolts, & cover does look like a dana 44 cover.
Old Nov 11, 2011 | 05:35 PM
http://www.drivetrainspecialists.com/categories/gm/
http://www.drivetrainspecialists.com/categories/dana/
Old Nov 11, 2011 | 05:45 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
9bolt has a rubber plug on the cover
dana has a metal plug on the cover
Old Nov 11, 2011 | 05:57 PM
sparky8131's Avatar
Cover has a metal plug.
Old Nov 11, 2011 | 06:08 PM
TTOP350's Avatar
Sweet welcome to the Dana club.
Snap a pic and post it if ya can!
Old Nov 11, 2011 | 06:28 PM
sparky8131's Avatar
Will do. Where can I find ring & pinion gears, and install kit for it?
Old Nov 11, 2011 | 09:13 PM
Ummmmm.... did you try the links I put up for you? Check Summit? Jeep places? (lots of those use Dana)
Old Nov 12, 2011 | 07:08 AM
sparky8131's Avatar
Unfortunately, this was made special for GM. From what I been able to find, common things from GM & Dana will not fit this.
Old Nov 12, 2011 | 12:31 PM
AFAIK, Dana 44 internal parts fit Dana 44 rear ends; period.
Things that adapt it specifically to any given chassis are a different matter, such as axles. Stuff like R&P and bearings, shouldn't be an issue.
Note that there are 2 versions of the 44, one with C-clips and one without. If memory serves, the without type is what the F-body model used. But that shouldn't matter to things like R&P and bearings because it doesn't touch any of that.
hectre13
Dec 11, 2023 08:14 AM
lt1z350
Sep 29, 2015 01:50 PM
Mickeyruder
Sep 2, 2015 02:45 PM
hectre13
Aug 26, 2015 08:17 AM
redmaroz
Aug 16, 2015 11:40 PM
