700R4 Won't shift into 4th gear.
Old Nov 22, 2011 | 06:17 PM
Unleashed Jimmy's Avatar
Car: 82 Converted IROC
Engine: 350ci TPI
Axle/Gears: 3.23 10-Bolt
Hey guys. I have an 86 Z-28 with the 700R4. A few years ago I replaced the 700 with a Raptor Junior level 2 from "700raptor.com". A little while back it stopped shifting into 4th gear. All of the other shifts are normal. I thought it might be the valve body so I replaced it with a TCI constant pressure valve body. When that didnt fix the problem i switched in a new stock valve body. Still wont shift into 4th gear. I have a B&M Mega Shifter up top but I don't think thats the problem. Any suggestions on what the problem could be? Thanks for your help guys.
Old Nov 24, 2011 | 09:55 AM
thirdgenmattw's Avatar
Car: '87 RS
Engine: LG4
Transmission: 4l60
Re: 700R4 Won't shift into 4th gear.
I'll take a semi-educated stab and say; investigate your throttle valve. They're known to stick in earlier models, which in some cases can cause no shifting. Also, the TV is supposed to keep the trans from shifting to 4th at or near WOT(unless it's a 'vette TV). So either the cable ain't adjusted right or the TV itself is bad.
Just a scientific-wild-***-guess
Old Nov 24, 2011 | 03:21 PM
Engine: 350ci TPI
Thanks for the response. I'll check both of those. It doesnt have the vette servo. It has a billet servo that is supposed to hold 35% stronger than the corvette servo. IDK. I will check into the TV Cable and the Valve for sticking though. Thanks.
jklein337
Sep 19, 2018 06:23 PM
camaro11j
Sep 19, 2018 08:49 AM
italiano67
Dec 11, 2016 09:21 AM
someone972
Aug 30, 2015 12:52 AM
drathaar907
Aug 6, 2015 04:20 PM
