1995 Manual Pedal Assembly. Brake Switch.
Old Nov 29, 2011 | 05:53 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
I have a 1995 LT-1 Pedal assembly for my 92 camaro. The switch holder circled in red, is that for a brake switch? If so, does anybody have a part number? Also where does the nuetral safety switch locate on the clutch pedal?
Thanks,
Attached Thumbnails 1995 Manual Pedal Assembly. Brake Switch.-cnc-master-1.jpg
Old Nov 30, 2011 | 10:59 PM
oamhmad's Avatar
Car: 84 Trans AM
Engine: Goodwrench 350 Crate motor
Re: 1995 Manual Pedal Assembly. Brake Switch.
Yes, the brake switch goes in the red circle. Not sure about the part number, but i know Pep boys and Auto zone both carry it.
Clutch safety switch mounts on a bracket behind the clutch pedal. I'll send you mine if you want it. I'm used to starting my manual cars in neutral so I never wired it up. I was just about to throw it away, but I'd rather it go to a fellow F-body owner.
1992 Trans Am
May 10, 2023 07:19 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
