reaer end identification help
Old Dec 7, 2011 | 08:09 PM
firebirdpower7's Avatar
Car: '91 firebird
Engine: 350 4bbl
Transmission: t56 6 speed manual
Axle/Gears: limited slip, 3.73 gears
i wanna find out what kind and size reaer end i have in my 91 firebird. it has a 305 and had an auto. there was a number on the bottom of it its 22522676. i really want to find out what the size is, i cant seem to find it from any research. from wht i can find its probably a gm 10 bolt open with 2.73s, though am not certain, but what i want to know is the size 8in, 7.5in, 8.5in ... ? any help would be appreciated
Old Dec 7, 2011 | 08:34 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: reaer end identification help
Count the rear end cover bolts.
9 bolt heads = A 9-bolt.
10 bolt heads = A 10-bolt.
Stock is the 7.5". You can jack the rear of the car off the car (use jack stands not just the jack), put the tranny in Neutral, then rotate the tire 1 full revolution & count the # of turns the driveshaft makes. 3 tire rotations to 1 driveshaft rotation is equal to a 3.08 gear. 2 3/4 tire rotations is equal to a 2.73 gear.
Those are your 2 most likely gears, for your combination.
As for Open vs Posi....If Open, only the Passenger side will turn or if both turn, the Drivers side can be very easily stopped & the tires will rotate in opposite direction. A Posi will make them rotate in the same direction.
Old Dec 7, 2011 | 08:38 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If the rear is OE, it's a 10-Bolt, so here's the FAQ:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Dec 7, 2011 | 11:24 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
According to the TGO tech data, the only option for a 91 Firebird with a 305 and an auto is the 2.73 gears. Your diff will be a 7.5/7.625" ring gear size and it will use 28 spline axles.
That's all assuming it's still original.
Old Dec 8, 2011 | 11:13 AM
Car: '91 firebird
Engine: 350 4bbl
thanks for the help guys
J-money
Jan 4, 2019 09:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
dbrochard
Sep 7, 2015 09:41 AM
SG91camaro
Sep 5, 2015 10:27 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
