T5 W/C trans issue with 2nd gear.
Old Dec 9, 2011 | 07:00 AM
jimmy2s83's Avatar
Car: 1992 Pontiac Firebird
Engine: 454 BBC
Transmission: TH400
So I took the plunge and bought a 91 firebird with the 5 speed manual trans. After reading up a little bit I found this trans is considered the world class T5.
The issue is the 2nd gear doesn't want to stay in while the clutch is being released. Once its in though it doesn't pop out. All other gears work fine without any issues.
My fear is the syncro but hoping this might be a linkage issue?
Any advice appreciated.
Thanks.
Old Dec 9, 2011 | 09:42 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: T5 W/C trans issue with 2nd gear.
It needs to come apart regardless. The fork / pads could be broken but that would tend to carry over to first gear. So it's probably synchro. Nothing to fear; tear it down and replace what's broken.
Old Dec 9, 2011 | 11:02 AM
jimmy2s83's Avatar
Engine: 454 BBC
Transmission: TH400
I don't have much experience in Manual trans so that is why its concerning. Should be a good learning experience either way.
Thanks for the tip.
Old Dec 13, 2011 | 09:38 PM
irocarter's Avatar
Car: 89 iroc
Engine: 5.7 trick flow heads t-ram
Transmission: wct5
more than likely, it's the "dogs" wore out on 2nd gear and 2nd gear will need replaced
junkcltr
Aug 2, 2019 11:12 PM
jklein337
Sep 19, 2018 06:23 PM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
