just a quick question about putting a t5 behind a crossfire
Car: 1983 daytona pace car
Engine: crossfire
Transmission: world class 5 speed
im thinking of swapping my auto to a t5 in my 83 Daytona pace car. i have a parts car already and ive read about the swap. just a quick question is there anything that is different in swapping behind the crossfire since it is computer controlled and all. anything i have to look out for
Re: just a quick question about putting a t5 behind a crossfire
AFAIK it shouldn't matter at all. The ECM in that setup reads nothing from the trans (directly... all it gets is indirect, the VSS, which is from the dash), and controls nothing in it except the TCC. Which incidentally, is driven by the same driver that drives the "Shift Up" light in a manual car. So don't put a bulb in that socket, it will come on whenever the ECM thinks it's time to engage the TCC.
Main thing you'll have to worry about is the crossmember. Your car might not have the rearmost bolt hole, that the T-5/700 xmbr needs. You'll also need to shorten the drive shaft, if you have the 200C. Although you can probably sell your current one to somebody looking to do a Turbo 350 swap for enough to mostly pay for your T-5/700 one.
Engine: crossfire
i have a 700r4 in the 83.
Car: `86 SS / `87 SS
T5 models have different wiring with regard to park/neutral start switch (copy your donor car)
The PROM in the ECM is different, with different timing and to a lesser extent, fuel tables.
With regard to the engine, it's just an 85-down neutral balanced flywheel. If your donor is 86-up, you'll need a different flywheel. Otherwise, you're good.
nesluopetan
Nov 1, 2001 03:58 AM
