clutch help
Old Jan 2, 2012 | 12:03 AM
91formula5speed's Avatar
Car: 1991 formula/83z28
Engine: 350/ 350
Transmission: wc t5/ non wc t5
Axle/Gears: 3.42/3.73
clutch help
I have a 91 formula with a 350 TPI and a world class t5 last night I blew the clutch out of it. Any suggestions on the clutch install never done a third gen. Any help appreciated.
Old Jan 2, 2012 | 06:33 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: clutch help
installs like any other clutch, but you have a hydraulic slave cylinder to activate the pressure plate, not linkages.
Be sure to assemble the fork and TO bearing correctly, and DO NOT push the clutch pedal when the slave is unbolted from the bellhousing, or you will destroy it. You may have to bleed the slave after install, there is a bleeder on top.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
Night rider327
Sep 2, 2015 04:18 AM
