borg warner upgrade
Old Jan 2, 2012 | 07:25 PM
zfisher89's Avatar
Car: 92 RS camaro
Engine: 5.0
Transmission: world class T5
Axle/Gears: borg warner 9 bolt
borg warner upgrade
i bought a 9 bolt borg warner rear this weekened came with disc brakes i currently have drums is there anything else ill need to do for the swap thanks
Old Jan 2, 2012 | 07:27 PM
jaben2's Avatar
Re: borg warner upgrade
i believe there is another valve that needs added. I am sure someone else will chime in.
Old Jan 2, 2012 | 08:07 PM
cerberus's Avatar
Car: 1985 IROC
https://www.thirdgen.org/forums/brak...ortioning.html
Old Jan 2, 2012 | 08:23 PM
zfisher89's Avatar
Car: 92 RS camaro
Engine: 5.0
thanks for the link what i get from it is i should be good with just swapping the prop vavle
Old Jan 2, 2012 | 08:26 PM
cerberus's Avatar
Car: 1985 IROC
yup thats what I understand also
Old Jan 2, 2012 | 08:47 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You'll also have to consider parking brake cables and drive and/or driven gears for the speedo, depending on the new rear's ratio.
BTW, there's no difference between 9- and 10-bolt braking systems, so the following will be useful as master cylinders, combination valves, parking brake cables and such as mentioned:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Jan 2, 2012 | 09:35 PM
zfisher89's Avatar
Car: 92 RS camaro
Engine: 5.0
it did come with brake cables not sure bout the gears thanks for the info
Linson
Oct 24, 2025 02:00 PM
6speedIROC
16
Mar 15, 2023 08:33 PM
PurelyPMD
May 5, 2016 04:57 PM
Zell1luk
Sep 29, 2015 10:36 AM
scottmoyer
Sep 7, 2015 07:06 PM
