3.08 gears in my rear end
Old Jan 4, 2012 | 07:22 PM
dame28's Avatar
Car: Chevy Camaro
Engine: 5.3 LS carb'd
Transmission: 700R4 on deck to be rebuilt
Axle/Gears: 3.08
I decided to go with the 350 that was in the car when I bought it, and install a new cam and rework the heads. to go with the new cam set up I want. I opened the rear end to see what gears where in it and 3.08 was what I got. Are these good or should I change them. The will be raced occasionally but mostly be on the highway running up and down playing with the car. I am not a gear head but I can turn wrenches with a little instruction>
Old Jan 4, 2012 | 07:25 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 3.08 gears in my rear end
not a performance minded gear ratio, so if you want a little more, you can go to a 3:42, which is a factory ratio. I do believe its a different carrier though, so you will need to get a different carrier or use the special thicker gears to fit what you have.
installing gears requires special setup or the gears will be noise and the life will be dramatically shortened. Its something to have done by a pro unless you know what you are doing.
Old Jan 4, 2012 | 07:48 PM
dame28's Avatar
Car: Chevy Camaro
Axle/Gears: 3.08
I have a buddy who in the vehicle maintanece shop on the base so I have access to presses and people who know what they are doing. I see alot of people with 3.73 is there much differrence between them and 3.42. and are the 3.08's just garbage?
Old Jan 4, 2012 | 07:53 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
The 3.08 if it should be a 9 bolt rear, which is a 3 series carrier. You can build a 3.45 or a 3.70. The 3.45 will get a little better mileage if that's a concern. You will also have to figure out and change speedometer gears in the tranny.
Old Jan 4, 2012 | 08:10 PM
dame28's Avatar
Car: Chevy Camaro
Axle/Gears: 3.08
its a 10 bolt rear end
Old Jan 4, 2012 | 08:40 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
There's much in the link below that you may find interesting:
https://www.thirdgen.org/forums/tran...-10-bolts.html
BTW, 3.08 is series II.
JamesC
Old Jan 6, 2012 | 08:43 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Well i have a 350 with 3.42's and now i barely have a first gear(700r4 trans). LOL
Old Jan 6, 2012 | 10:40 PM
dame28's Avatar
Car: Chevy Camaro
Axle/Gears: 3.08
Why is that?
Old Jan 6, 2012 | 11:08 PM
ninetyone's Avatar
Axle/Gears: 3:42
Why is that?
cause the 700r4 has a very low first gear to begin with (3.06), and tpi makes tons of low end torque anyway. 3.42 is the tpi auto car's 3.73 as far as i am concerned.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
mizz0313
Aug 12, 2015 06:45 AM
