Driveshaft question?
Old Jan 5, 2012 | 11:20 AM
reride's Avatar
Car: 1989 IROC-Z Convertible
Engine: 5.7 TPI
Axle/Gears: 3:23 Posi w/ alum. driveshaft
After searching for driveline lengths I found that 3rd & 4th gen shafts should be 41.5" from center to center of u-joint.
I have found a alum shaft that is 40 & 7/8" in length (one piece) but it has a dampner on the slip yoke. The dampner is about 1" in width. It is currently in a '94 V6 car. Would this shaft work w/700R4, or would the difference in length cause vibrations due a slightly different pinion angle?
The driveshaft is going for $30 so it is a good deal if I can use it.
Any input would be helpful and Thanks.
Old Jan 5, 2012 | 08:21 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Driveshaft question?
from my experience, 3rd gen shafts are 41.5 center to center and the 4th gen shafts are 40.5. both will work just fine though. I think all 4th gen shafts have the damper.
30 bux is a great deal
Old Jan 6, 2012 | 04:00 PM
reride's Avatar
Engine: 5.7 TPI
86TA, Thank you very much! When the guy said $30 you could have pushed me over with a feather.
Irocguy01
Sep 28, 2015 02:03 PM
theshackle
Aug 23, 2015 03:49 PM
overdriv
Aug 20, 2015 03:52 PM
redmaroz
Aug 16, 2015 11:40 PM
