Re and re'ing trans cross member 83 Z28
Old Jan 26, 2012 | 03:19 PM
garys83's Avatar
I recently had my auto trans serviced. The tech removed the cross member to remove the pan on the trans. After the service, when the cross member was re-installed one of the bolts didn't tighten up very good because the threads in the nut "welded" to the unibody was weak.
Has anyone had any experience fixing this? I would like to fix it with a helicoil because I want to use the same factory bolts.
A gent who is a pro at repairing cylinder head and exhaust threads told me that he'd ruin his tools if he tried to install a helicoil in this place on my unibody frame.
I think it would be the exact type of repair for a helicoil.
Does anyone have any comments or advice? Thanks.
Old Jan 26, 2012 | 06:11 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Re and re'ing trans cross member 83 Z28
if the wedled nut has not actually broken from the sheetmetal, the common fix is to drill the hole larger and re-tap it to a larger size, i think 7/16-fine thread is the next common size? check it out.
i dont think the insert is thick enough to use a helicoil.
Old Jan 26, 2012 | 06:42 PM
Right: it's not really quite a "nut"; it's some chinesium junk loosely held in an approximately correct area by a little sheet-metal cage.
I wouldn't mess with it if it's screwed up. Tapping it is only a temporary solution at best, even if it ever works at all. Sometimes the reason they screw up isn't even because they're "stripped"; rather, it's because the chinesium "nut" split, like a lockwasher. You can tap that every day from now til Doomsday, and twice on Sundays for good measure besides, and still NEVER get a bolt to hold in that.
Correct way to fix it is to take a hole saw to the floor pan right above it; nuke the lame factory one-time-use garbage; and put an actual NUT there instead. Made of steel and everything.
Old Jan 27, 2012 | 10:42 AM
garys83's Avatar
Thanks for your reply, 86TA. I thought about going 7/16 but I wanted, if possible, to repair these threads such that I could use the original bolts and have all four bolts on the cross member be the same. I may just have to go "oversize" to make the cross member solid. I appreciate your response to my post. Thanks.
Old Jan 27, 2012 | 10:46 AM
garys83's Avatar
Sofakingdom: I didn't think of replacing this "nut" and I didn't think that it might be split. If I was to go through the floor and installed a real nut -> that would be the 100% job. Thanks for pointing all of this out to me. Gary.
1992 Trans Am
May 10, 2023 07:19 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
