stripped cross pin bolt help
Old Jan 27, 2012 | 02:23 PM
psmith757's Avatar
Car: 91 Camaro RS
Engine: 5.7 350 TBI
Transmission: t56
Axle/Gears: 4.10
i was installing my 4.10s and the cross pin bolt got stripped and now im stuck. anyone know what i should do from here?
Old Jan 27, 2012 | 03:34 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: stripped cross pin bolt help
Stripped the hex of the bolt?
Stripped the head off the threaded part of the bolt?
Stripped the threaded bolt off the smooth pin?
If it's still partially threaded into the diff and has no hex head, start w/ a small left hand drill bit at the centre of the remaining bolt.
Old Jan 27, 2012 | 03:39 PM
psmith757's Avatar
Car: 91 Camaro RS
Engine: 5.7 350 TBI
Transmission: t56
Axle/Gears: 4.10
I stripped the head of the bolt that hold the pin in that hilds the c clips
Old Jan 27, 2012 | 03:46 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
See if you can turn the remnant out with a scriber or pick. Usually they break off at the last thread so there's not too much holding it in.
Old Jan 27, 2012 | 03:50 PM
psmith757's Avatar
Car: 91 Camaro RS
Engine: 5.7 350 TBI
Transmission: t56
Axle/Gears: 4.10
Wht do you mean?
Old Jan 27, 2012 | 03:56 PM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
Axle/Gears: 4.10's / Strange LSD
Are you saying you rounded the head of the bolt or you broke the head off the bolt?
Old Jan 27, 2012 | 04:02 PM
psmith757's Avatar
Car: 91 Camaro RS
Engine: 5.7 350 TBI
Transmission: t56
Axle/Gears: 4.10
the head is rounded. its a 5/16 bolt and is in a tight spot
Old Jan 27, 2012 | 04:12 PM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
Hmm, Never had that happen on a pin bolt. I'm guessing you used a 6 point socket, If it was me I would try tapping the next size smaller metric socket on the head, if that doesn't work I would drill a hole in the head and use a easy out. Sorry I couldnt be more help. Maybe someone else will chime in who have ran into that. Good luck.
Mark.
Old Jan 27, 2012 | 04:28 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
There's a tool especially designed to extract these. Got mine from skyway tools: Differential Repair Kit ST 1440
Old Jan 27, 2012 | 04:39 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
My guess is that he didn't use a 6-point--at least I've always used one to good effect; it's the 12-point that usually causes issues. At any rate, tool in post #17 of the link below:
https://www.thirdgen.org/forums/tran...ing-axles.html
JamesC
Old Jan 27, 2012 | 04:49 PM
psmith757's Avatar
Car: 91 Camaro RS
Engine: 5.7 350 TBI
Transmission: t56
Axle/Gears: 4.10
Its all good thanks man
Old Jan 27, 2012 | 07:37 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
. If it was me I would try tapping the next size smaller metric socket on the head,
Mark.
i second this.also sears craftsman makes special sockets that will grab rounded bolt heads.
Old Jan 27, 2012 | 08:49 PM
psmith757's Avatar
Car: 91 Camaro RS
Engine: 5.7 350 TBI
Transmission: t56
Axle/Gears: 4.10
Ok ill give that a try thanks
Old Jan 28, 2012 | 09:22 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
hammer and a small chisel works for me
Old Jan 28, 2012 | 10:07 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
You can also use a lil valve grinding compound on all the sides of the bolt flats for more grip. If your trying to get it out you can use heat to loosen the thread locker 1st. That makes it easier to remove..
Old Jan 28, 2012 | 01:16 PM
psmith757's Avatar
Car: 91 Camaro RS
Engine: 5.7 350 TBI
Transmission: t56
Axle/Gears: 4.10
The bolt is so seatroyed now ive tried so mny things im gonna try to drill it out
evilstuie
Jan 9, 2020 08:29 PM
deracer
Apr 11, 2016 12:04 AM
gixxer92
Sep 1, 2015 04:32 PM
Hawkeye1980
Aug 31, 2015 07:09 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
