3.73 gears&Rev limiter
Old Feb 6, 2012 | 10:39 PM
Rondeezzee310's Avatar
Car: 91 rs camaro
Engine: 305 v8
Transmission: 700r
Axle/Gears: 373
I ve just installed 3.73 gears in my 91 rs ,but now I'm hitting the rev limiter to soon. I know I can buy a new ebl flash ecm to fix the problem for 400 bucks but hear that there are ways to fix this cheaper. Any help I get would be wonderful
Old Feb 7, 2012 | 01:06 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: 3.73 gears&Rev limiter
Sounds like you need to change the speed sensor or speedo gear. Whichever the car has.
Old Feb 7, 2012 | 01:20 AM
Car: 91 rs camaro
Engine: 305 v8
Transmission: 700r
Axle/Gears: 373
I was also told I could put a switch on vss wire at the ecm but id rather not cut into the harness. I guess some how the gear change moved the speedo up to 110mphs to soon so I'm hitting the governor. I just need to know how to recalibrate the speedo for the gear change.
Old Feb 7, 2012 | 07:42 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The TBI vehicles don't have a rev-limiter in the ECM, they do have a speed limiter. Which is what it is hitting.
Need to swap the driven & possibly the drive gear for the VSS. They are located in the transmission tail-housing.
See the sticky's up top, there is one for the 700R4 speedometer gears.
RBob.
Old Feb 7, 2012 | 04:29 PM
bracket rs's Avatar
yep, when i put my 4:10's in i just bought a speedo gear from the dealer, like $10.00
and it slowed the speedo down
Old Feb 7, 2012 | 08:47 PM
Car: 91 rs camaro
Engine: 305 v8
Transmission: 700r
Axle/Gears: 373
So I need to go to a dealer of some sort an ask for a speedo gear for 3.73 gears?
RedLeader289
May 28, 2019 01:47 PM
Ed1LE
Sep 30, 2018 09:14 AM
racereese
Oct 3, 2015 03:46 PM
drumstixer
Sep 29, 2015 03:02 PM
JSDaddy189
Sep 26, 2015 03:50 PM
