t56 speedo trouble
Old Feb 9, 2012 | 01:52 PM
firebirdpower7's Avatar
Car: '91 firebird
Engine: 350 4bbl
Transmission: t56 6 speed manual
Axle/Gears: limited slip, 3.73 gears
t56 speedo trouble
i did a t56 swap in my 91 firebird (originally had an auto) and it drives great, love it. i finally got around to hooking up some of the wiring and all went well except for the speedo. i got new plugs from hawks third gen and i just hooked up the plug to the wires that were on the original plug (yellow and purple). iknew it was going to be off but went ahead with it anyway. first off it read i was doin 100 when i was crawlin out of the drive way and when i got on the road to try and drive it the car didnt want to go anywhere. the engine was sputtering and dieing and stalling and it didnt want to move. i unplugged the wire and it was back to normal. so whats the problem and how do i fix it?
Old Feb 9, 2012 | 02:08 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: t56 speedo trouble
Dakota Digital SGI-5 converter box.
T56 VSS isnt calibrated for your speedo. That converter box will fix it though.
Old Feb 9, 2012 | 02:11 PM
Car: '91 firebird
Engine: 350 4bbl
where can i get one and for how much?
Old Feb 9, 2012 | 02:40 PM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
is it a 2000ppm or 4000? i did this on mine when i went LSx, i had to jump some wires on the buffer box....
Old Feb 9, 2012 | 05:30 PM
Car: '91 firebird
Engine: 350 4bbl
i dont know, how can you tell?
Old Feb 9, 2012 | 05:47 PM
maybe pocket will chime in......?
Old Feb 9, 2012 | 10:46 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
The stock VSS puts out a LOT fewer pulses than the T56 VSS setup. Here, in the T56 sticky thread is the how-to-fix: https://www.thirdgen.org/forums/post...1-post147.html
Neither. My explanation of the differences:
https://www.thirdgen.org/forums/post...417-post4.html
Old Feb 11, 2012 | 10:23 AM
Car: '91 firebird
Engine: 350 4bbl
ok well i guess im gonna have to find one of those decoder boxes. thanks for the help guys
Old Feb 11, 2012 | 02:56 PM
Car: 1992 Camaro RS
its available at Summitracing... not too expensive:
http://www.summitracing.com/parts/DAK-SGI-5/
Old Feb 14, 2012 | 08:12 PM
Car: '91 firebird
Engine: 350 4bbl
thanks, i'll order it now
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
mrbird
Oct 20, 2015 03:43 AM
meeklay812
Oct 1, 2015 03:46 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
Vincent135
Sep 28, 2015 10:50 PM
