t56 behind a v6
Old Feb 11, 2012 | 02:44 PM
project89's Avatar
t56 behind a v6
im planning on a new build a 3.4 turbo motor with a t56
mounting the trans is the easy part
speedway motors 60* v6 to 90* v8 trans adapter plate for 45$
and of course a t56 crossmember
what im curious about is the clutch
spec makes clutches for the v6 that will hold like 800hp 800 ftlbs
my thinking is use a spacer for the flywheel to space it back out the thickness of the trans adapter
use a 3.4 flywheel and presure plate with a custom disk for the t56
what size is the input shaft on the t56 and how many splines are on it
im thinking maybe i can find somethign from spec or another company that i can use without having to custom order a disk
Old Feb 11, 2012 | 04:36 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Re: t56 behind a v6
subscribing... I'm very interested in this...
Old Feb 11, 2012 | 05:29 PM
project89's Avatar
Re: t56 behind a v6
we already figured this out in the v6 section after i posted this
to use a t56 behind the v6 u will need
a speedway motors trans adapter 60*v6 to 90*v8
all the typical t56 conversion parts i.e crossmmeber etc
the clucth is the easy part the t56 uses the same size inpout shaft and has the same spline count as a t5 behind a 92/93 3.4 in an fbody
so for a stock clutch u would use a 92/93 3.4 v6 fbody clutch
or u can buy the equivelant in an aftermarket clutch i.e spec or ram etc
the hardest thing would be making a spacer to space the flywheel off the crank the thickness of the trans adapter and that shouldnt even be to hard
Old Jul 13, 2012 | 11:39 AM
slashervrgr's Avatar
Car: 93 Firebird
Engine: 3.4l 60° v6
Transmission: t-5
Axle/Gears: 323s
Re: t56 behind a v6
Hey, I am planning the exact same thing in my 93 bird.. I was wondering, could you not just shave off the thickness of the adapter from the bell housing? I've been thinking this for a while and joined this site after finding this thread.
Also sorry to dig up a 4 month old thread but I was just curious.
Edit: Can I get a link to this 60° to 90° adapter? O.o
Old Jul 13, 2012 | 01:02 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: t56 behind a v6
Why wouldnt you just use the "aftermarket" conversion T56 which has the bolt on plate to the T5 bellhousing, which has the appropriate length input shaft for an adapter already taken into account.
You could also swap the input shaft from an LS1 T56, or use the whole thing, its got a longer input shaft than the LT1 boxes.
Clutch disc spline needs to be GM "1-1/8" x 26, the 1 1/8 in quotes because its also known as 1-5/32.
Old Jul 13, 2012 | 01:27 PM
Car: 93 Firebird
Engine: 3.4l 60° v6
Transmission: t-5
Axle/Gears: 323s
Re: t56 behind a v6
They make those!? Where abouts would I find one of those?
Old Jul 13, 2012 | 01:29 PM
58mark's Avatar
Re: t56 behind a v6
which t56 would be easier/ better? the LT1 version or the LS1?
Old Jul 13, 2012 | 01:31 PM
Car: 93 Firebird
Engine: 3.4l 60° v6
Transmission: t-5
Axle/Gears: 323s
Re: t56 behind a v6
This "aftermarket" one that bolts to my t-5 bell housing? That would be amazing!
Old Jul 13, 2012 | 02:02 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: t56 behind a v6
when you start playing with bellhousings deeper than the LT1 bellhousing, the LT1 maindrive (input shaft) is a bit short. The LS1 maindrive is shorter than the aftermarket but an extended pilot bushing/bearing can accommodate for that.
Old Jul 13, 2012 | 02:06 PM
58mark's Avatar
Re: t56 behind a v6
soo... either? the LT1 t56's seem to be less in demand, so they are more affordable
Old Jul 14, 2012 | 07:46 AM
Car: 93 Firebird
Engine: 3.4l 60° v6
Transmission: t-5
Axle/Gears: 323s
Re: t56 behind a v6
What exactly would I need to bolt the t56 to my 3.4 than? Because I'm almost positive my t5 bell housing wouldn't just bolt to a t56
Old Jul 14, 2012 | 10:31 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Re: t56 behind a v6
There is a "retrofit" T56 setup that is designed to do exactly that.
http://www.keislerauto.com/vmchk/gm/...page_tabs.html
Not going to chase down someone actually selling it for you, but that gets you in the right direction, iirc its something around $2500.
"Bolt-in installation in 5-speed equipped 1983-1992 Camaro and Firebird, direct replacement for the original T5 five speed. "
Old Jul 14, 2012 | 10:35 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Re: t56 behind a v6
Or just the adapter plate, use this with an LS1 T56, or an LT1 T56 with LS1 input shaft installed.
http://www.thegearbox.org/catalog/it...17/4803441.htm
Old Jul 14, 2012 | 03:50 PM
jmd's Avatar
jmd
Re: t56 behind a v6
Hey look, Keisler is lying about torque ratings again.
Old Jul 14, 2012 | 05:17 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Re: t56 behind a v6
Interesting, same gear set as the MN12 in the GTO, and Z06, and CTSV, guess the Z06's 470 ft lbs must be breaking them left and right, since thats a lie.
Old Jul 14, 2012 | 09:21 PM
Car: 93 Firebird
Engine: 3.4l 60° v6
Transmission: t-5
Axle/Gears: 323s
Re: t56 behind a v6
Thanks all for the help!
Old Jul 15, 2012 | 12:10 AM
jmd's Avatar
jmd
Re: t56 behind a v6
A new maindrive (input shaft) for an LS_ trans is 2 bills so if you're doing the adapter plate thing, an LT1 box is not the way to go.
Did you have something add besides misinformation?
Old Jul 15, 2012 | 12:06 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
Re: t56 behind a v6
??? that torque rating doesn't sound out of line to me, where are you getting your info?
Old Jul 15, 2012 | 01:18 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Re: t56 behind a v6
The only one in here adding misinformation is you.
So far the only thing relevant to the topic you've provided is to repeat what i've stated about switching input shafts.
And argue with a torque rating of a transmission thats more than feasable.
Old Jul 15, 2012 | 01:45 PM
jmd's Avatar
jmd
Re: t56 behind a v6
The aftermarket T56 and the 93 F-body 2.97 / .62 gearset was always rated by Borg Warner and Tremec at 400lb-ft at most. Not 475lb-ft as Keisler plumps it up to.
Keisler has always rated their T45 based trans. with no meaningful strength upgrades significantly higher than the production T45 too.
As for your claim the aftermarket T56 gearset is the same as a Z06 or GTO, it's not. Even ignoring the synchronizer section of the gears, it's weaker. What's the first place a non-cooled manual trans. is going to break when subjected to a lot of power and run at high speed? The headset gears, which are... narrower and weaker on the aftermarket T56.
So no, it's not a 475lb-ft trans., and that wasn't even a jab at you, just Keisler. I'm guessing you're a happily confused customer of theirs so you opted to take it personally?
You're welcome.
Old Jul 15, 2012 | 02:13 PM
Car: 93 Firebird
Engine: 3.4l 60° v6
Transmission: t-5
Axle/Gears: 323s
Re: t56 behind a v6
-_- why does everyone always argue when I post on a thread lol
Old Jul 15, 2012 | 02:23 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Re: t56 behind a v6
You're welcome.
The same ratios as the CTSV/GTO/Z06 is in hursts "magnum" T56 rated for 700 ft lbs, its not all just in the gearset.
Why is it you figure the gears are narrower on that T56 ? The likelyhood of them making an entirely new gearset, in the same ratios of those already available is highly unlikely.
Old Jul 15, 2012 | 02:28 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Re: t56 behind a v6
You say its rated at 400 at most.
http://www.tremec.com/performance/t56.html
Tremec says 450
Its well known that they are much stronger than the "ratings", ratings are just a ballpark idea, and vary from on manufacturer to the next.
Some clutch manufacturers give a HP or torque rating on their clutches, then go to say that you need to select a clutch with 1.5x what youre making, if you look at tiltons clutches they say use a clutch with a 400 tq rating, with your 400tq, realistically the 475 lbs listed for that T56 isnt even close to where you're gonna hurt it.
Old Jul 15, 2012 | 07:14 PM
jmd's Avatar
jmd
Re: t56 behind a v6
The Magnum isn't a T56, it's a TR6060. That entire gearset is wider than any T56.
The front adapter plate is from the Viper casting, and it's machined shallower for the front bearing.
The front headset gears are narrower, which is why the countershaft from a 1993 M29 RPO Camaro doesn't interchange with a 2004 GTO (they otherwise would.)
The only new gearset piece in a GM Aftermarket T56 is the maindrive (input shaft) which is simply longer. Everything else is 1993 M29 F-body. If you can explain how a shorter shift rail and a longer input shaft take a trans. from 400lbs-ft (the max torque rating of the M29 per Borg Warner) to 450, I'm all ears.
Tremec says 450
Keep in mind Tremec bought the light duty line from Borg Warner and a carry-over typo from over 10 years ago (which is exactly what that is) doesn't hold any weight.
Right, a constant load rating is different than what a trans. can take on a temporary run.
Old Jul 15, 2012 | 09:41 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: t56 behind a v6
The concern isn't the torque capacity. Nor is it the installation. The issue is the ratios. Using the '94-'02 V8 ratios means you'll only have 5 useful gears no matter what axle ratio you try. Use a 4.56:1 to make sixth useful with a 3.4, first will be way too deep. Use a 3.73:1 to make first useful, sixth will be too tall.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
