changing to a posi ...
Old Feb 19, 2012 | 01:55 PM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
what do i need to change to make the speedometewr right ? i'm going from a 2.73 :! to a 3.23 :1 posi out of a 87 iroc ...
Old Feb 19, 2012 | 02:33 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: changing to a posi ...
you need to change the drive/driven gears in the trans tailshaft to the proper ones. If you can get them off the car the rear come from, that would work too.
Old Feb 19, 2012 | 03:28 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You may find the stickies at the top of the page useful.
JamesC
Old Feb 19, 2012 | 11:51 PM
blue birdy 87's Avatar
Car: White 84 z28
Engine: Chevy 350
Axle/Gears: Posi and?
https://www.thirdgen.org/forums/tran...eedometer.html
Old Feb 24, 2012 | 05:46 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
this rearend is from a 87 iroc with disc brakes i'm thinking it should be a direct swap but if not i'm hoping one of you guru's can enlighten me as to what won't work thanks
Old Feb 24, 2012 | 07:05 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
if you're going from drum to disc, you *should* change the prop valve. also will have to change the ebrake cables.
guessing its got different gears, so you'll have to change the speedo gears in the trans (as previously mentioned)
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
mcgarnicle
Aug 12, 2015 04:58 PM
