700R4 to T56 swap speedo question
Car: 1988 Pontiac Trans Am
Engine: 5.0 TPI
Axle/Gears: 2.73 Posi
I have an '88 Trans Am with the digital dash and I want to put a 6 speed in it but i was wondering how to keep the speedometer working since its digital.
Re: 700R4 to T56 swap speedo question
theres a place called transmission world. They have all the parts to adjust it. Most likely you will have to buy the sensor for the 6 speed that plugs into your car. Youll have to google it i dont know the web address.Call them they will tell you what you need.
Car: `86 SS / `87 SS
The digital dash speedometer and the round gauge speedometer are both electronically driven from a VSS signal. So your question is the same as in this thread:
https://www.thirdgen.org/forums/tran...o-trouble.html
in which I linked to the T56 swap sticky thread. Read through that; it's worth it.
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
I just used the Dakota Digital to convert the signal, works great
Engine: 5.0 TPI
Thanks guys I really appreciate it by the way any tips on the reverse lights when swapping? Im guessing I can just take a manual reverse switch out of a third gen with a T-5 right?
Car: 87 Trans Am GTA
You can buy whatever pictails you need from www.tpiparts.net. That's where I got my parts from. As for the speedo, I am also running a Dakota Digital SGI-5C box, but I'm having some interference issues in that sometimes when I'm not moving, the speedo will jump to 50mph and go crazy. I'm going to try adding in a noise filter and getting the ground shorter.
find a pigtail to fit the reverse light switch in the trans.
find the wires under the dash/ shifter area (I think on the third gen, they go to the shifter.)
Connect them.
Connect them.
1992 Trans Am
Aug 8, 2015 08:16 PM
02, 88, 92, camaro, conversion, digital, generation, sensor, signal, speed, speedo, speedometer, swap, t56, transam, transmission
