TH400 Drive gear and driven gear question
Old Feb 22, 2012 | 03:25 PM
tmsumner1's Avatar
Car: 87 Iroc Z-28
Engine: 388 SBC
Transmission: 700R4 to modded TH400
Axle/Gears: 7.5" 4.10 to 9" 3.70
I just did a TH400 swap into my 87 Iroc. I am needing some help on figuring out what drive gear and driven gear I need for a 3.70 rear end ratio. It is a mechanical speedo. Thanks.
Old Feb 24, 2012 | 07:58 AM
tmsumner1's Avatar
Car: 87 Iroc Z-28
Engine: 388 SBC
Re: TH400 Drive gear and driven gear question
Anyone?
Old Feb 24, 2012 | 08:35 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
As long as you have 44" Super Swampers and a healthy lift on that Camaro, you're gonna need a ratio adapter too.
Got tire size?
Most of the 700-R4 speedo gear wisdom here is going to be the same w/ each having an available 15 tooth drive gear (and others.)
Every "speedo gear calculator" gives different results than what GM used in production vehicles.
So...
Got tire size?
Vintageracer
Jan 10, 2020 05:33 PM
jklein337
Sep 19, 2018 06:23 PM
jharrison5
Aug 19, 2015 05:53 PM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
