t56 clutch problems HELP!!
Old Feb 26, 2012 | 02:24 PM
firebirdpower7's Avatar
Car: '91 firebird
Engine: 350 4bbl
Transmission: t56 6 speed manual
Axle/Gears: limited slip, 3.73 gears
i completed a t56 swap in my 91 firebird and it was great for a lil more than a month and then all of a sudden the brand new ram clutch was slipping very badly. after we took it apart we saw that all that was left of that new clutch was a bunch of dust but their was no evidence of something being wrong such as oil getting on it or something not put in right. we had a theory that the hydralics were bad and not completely engageing/disengageing so we got a new clutch and installed new master and slave cylinders but after only about 40 miles of testing the clutch is already bad. my dad seems to think that the pedal doesnt have enough travel and that is causing the problem. i have the fourth gen pedal assembly in the car. i really dont know whats wrong though. i would really apreciate anything to shed some light on the situation. i realy need the help badly
Old Feb 26, 2012 | 02:33 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: t56 clutch problems HELP!!
You're using 4th gen hydraulics or 3rd gen?
You have a pilot bushing or bearing installed?
Should be pretty easy to test if you're getting full disengagement. Id put the car in the air andput it in gear and hold the clutch in and do some experiments to find out how much torque is making it to the rear wheels. Or rev it in reverse on the ground with the clutch in and see if it goes anywhere.
Other problem is that maybe you're not getting complete engagement. Not sure how that would happen, but if the clutch isnt grabbing all the way it could slip constantly.
Old Feb 26, 2012 | 02:35 PM
Car: '91 firebird
Engine: 350 4bbl
to be more clear, when you push the clutch pedal its not completely disengaging. so some of my main questions are
1: is there a problem with the fourth gen pedals? would third gen pedals work better?
2: does the spacer for the slave cylinder comein different sizes? if so could i have the wrong size?
3:is it possible that i didnt quite position the slave cylinder correctly when i mounted it to the firewall? ( i just followed the imprint that was already on the rug n firewall)
Old Feb 26, 2012 | 02:38 PM
Car: '91 firebird
Engine: 350 4bbl
im using 4th gen hydralics. just before i parked it again it was bad and the car would move with the clutch all the way down and if it was in nuetral i couldnt put it in gear
Old Feb 26, 2012 | 02:39 PM
Car: '91 firebird
Engine: 350 4bbl
it wasnt like that when i was first testing it just rite at the end
Old Feb 26, 2012 | 02:45 PM
Car: 1992 Camaro RS
Sounds like you have some serious hydraulics issues somewhere.
Did you buy the master and slave cylinders separately? GM sells the T56 hydraulic assembly as a pre-bled, bolt-in package and it's pretty fool proof.
Even if your hydraulics arent mounted properly the geometry shouldnt be off that bad.
3rd gen pedals will over-extend the slave cylinder due to different pedal geometry, so in taht sense they may "help", but I dont think that's the proper solution here.
Old Feb 26, 2012 | 02:48 PM
Car: '91 firebird
Engine: 350 4bbl
well the original ones i had were off the car in one piece. the new ones i got seperately and used the same line because it was still god. made sure to fill and bleed it all good though
Old Feb 26, 2012 | 03:25 PM
Car: 1992 Camaro RS
Well, if you're not getting full disengagement, then I would assume air is leeching in somehow.
Old Feb 27, 2012 | 09:24 AM
Car: '91 firebird
Engine: 350 4bbl
ok, i'll look into that, see if their is any air gettin in. but is their anything else that might be causing this problem
Old Nov 1, 2012 | 10:55 AM
3rdGenMess's Avatar
Car: 1990 RS
Engine: SBC 350 YearOne Crate
Transmission: T56 (LT1)
I ran into this issue when i was doing my swap...i man handled that transmission in and out bout 4 to 5 times dealing with a bad clutch...its best u get a brand new one already assembled and bled...the smallest leak can lead to the biggest problem
Old Nov 11, 2012 | 09:48 PM
Car: '91 firebird
Engine: 350 4bbl
ya i ended up just getting new master n slave cylenders n it fixed the problem
Old Nov 12, 2012 | 11:44 PM
oamhmad's Avatar
Car: 84 Trans AM
Engine: Goodwrench 350 Crate motor
To make sure the problem is fixed put jack stands under the rear axle, put the transmission in 1st gear, push the clutch in and rev the motor. The rear wheels should not move at all, not even the tiniest bit.
BlackphantomZ28
Apr 24, 2016 08:14 AM
19irocz85
Aug 31, 2015 10:31 PM
19irocz85
Aug 26, 2015 07:54 PM
hokis
Aug 9, 2015 03:57 PM
rsrmoore
Aug 7, 2015 08:44 PM
