Stock computer for TCC control
Old Feb 29, 2012 | 12:44 PM
transamice's Avatar
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
By using an aftermarket efi setup for engine management would it be possible to use a stock computer to control the TCC control separately and if so which of the pins on the stock computer (165 MAF) should be used?
Im guessing pins:
A6 - IGN
A7 - AT TCC control
A10 - VSS
C8 - Higear
A12 - GND
C14 - TPS
Would that cover it for the stock computer?
Old Mar 1, 2012 | 04:11 PM
transamice's Avatar
Car: 87 GTA t-top
Re: Stock computer for TCC control
Anyone???
Im sure with older aftermarket efi systems they used the stock computer just for TCC control.
Old Sep 4, 2012 | 07:08 AM
406irocz's Avatar
I am trying to do the same thing. No luck so far though.
Old Sep 4, 2012 | 07:18 AM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
No. The stock computer needs input to manage the TCC which is going to your aftermarket now, which should also be able to control your converter lock up. I suggest a call to the manufacturers help line.
Old Sep 4, 2012 | 08:12 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Options
https://www.thirdgen.org/forums/carb...c-control.html
eightsixseven
Dec 16, 2024 01:50 PM
9192camaro
16
Feb 3, 2019 12:21 AM
midge54
Jan 29, 2017 07:00 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Thirim
Aug 9, 2015 06:19 PM
