T5 hydraulics install
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Ok so i need help im putting a wc t5 from a 89 formula into a 88 an noticed there isnt a hole for the master cylinder where is the exact location i have to drill a hole for the master pics would be greatly appreciated
Car: `86 SS / `87 SS
Re: T5 hydraulics install
Use that 89 formula or another factory stick 3rd / 4th gen for reference.
Install the pedals so you have the pedal-bracket to firewall bracket in place.
Mark the two holes for that which is what the u-bracket bolts through.
Remove the gasket from the master cylinder if it has one and use that against the two bracket holes to mark for the cylinder hole.
ambainb
Apr 25, 2016 09:21 PM
gixxer92
Sep 1, 2015 04:32 PM
rsrmoore
Aug 7, 2015 08:44 PM
