Transmission question
Old Mar 2, 2012 | 04:08 AM
DiabloWS6's Avatar
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
I had my car at dyno don shop he found a leak in the lines I had installed I drove it back to lancaster , ca.. traffic was bad basically the trans felt ok some slip was noticeable over drive was good but then I ran dry I know it was bad I put in my last $10 on atf which is not much but made it home it made some unusual wine noises and did not want to shift to overdrive due to little or no oil cause it leaked it my question is if I drove it like that is there a possibility that I burned up the friction plates and messed up the trans and would have to rebuild or get a new one or might it barely make it by fixing the leak and adding atf and filter?
Old Mar 2, 2012 | 04:15 AM
lolvtec's Avatar
Car: 1991 camaro RS convertible
Engine: EFI 383 150shot nitrous.
Axle/Gears: 2:73...
Re: Transmission question
thats how i burned mine up in my old 77 c10 you can always just add fluid and see if it drives
Old Mar 2, 2012 | 10:57 AM
DiabloWS6's Avatar
Thanks for the input I will do that plus it's a cheap way to know if its good or bad just by adding new fluid and a filter and like you said see if it drives
Old Mar 2, 2012 | 01:03 PM
lolvtec's Avatar
Axle/Gears: 2:73...
yep
Old Mar 2, 2012 | 05:40 PM
krisner89's Avatar
Car: 87 camaro
Transmission: th350
Axle/Gears: auburn 4.10
Id fix that leak also before you test it because it might affect how it shifts,slips, and all that. lucas trans fix seems to work good if its still acting funny. For sure took some life out of it if not all.
Old Mar 4, 2012 | 12:20 AM
DiabloWS6's Avatar
True that the leak is a loss of pressure ...I hoping I didn't mess up the transmission to much
Vintageracer
Jan 10, 2020 05:33 PM
Cleotiz
Jan 6, 2018 08:56 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
redmaroz
Aug 16, 2015 11:40 PM
