How much does a Built 700R4 usually cost?
Old Mar 5, 2012 | 05:09 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I am looking for a tranny that will hold about 400rwhp on motor, and around 500 on spray.
How much will a good built 700r4 cost me? What are some affordable companies.
Right now it is a toss up between a built stalled 700r4 or a T56 swap. I have a feeling a T56 swap might end up being cheaper.
Old Mar 5, 2012 | 05:23 AM
lectric80's Avatar
Car: 83 Z28 T-top
Engine: 350 carb'd
Re: How much does a Built 700R4 usually cost?
I know a BTO 700r4 Stage 3 full manual valve body is going for around $1900 and is rated for 630 HP/TQ max. The same is available in a true auto, without the manual valve body, for about $1600. Both come with a 1 year warranty and BTO has a good reputation for build quality. Edit: Sorry I guess I should say BTO = Bowtie Overdrives.
Old Mar 5, 2012 | 09:38 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Check out a company called gear star. They are good.
Old Mar 6, 2012 | 11:42 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
http://www.performabuilt.com/level-2.html
Old Mar 7, 2012 | 12:39 AM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Get a 4l80e and be done.
Old Mar 7, 2012 | 01:29 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Would that require me to chop into my transmission tunnel? And isn't it electronically controlled?
I should add that I am on a pretty strict time budget... a T56 swap is in reason time wise though.
Old Mar 8, 2012 | 10:15 AM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
i have a 480e in my garage.... WAY too big and alot heavier and you need a conversion hub to fit the driveshaft of our cars...... its alot of work... i would go with dana's street/strip tranny.... its 1900 dollars on his site.... plus add another 750 for a vigilante stall... that would be a super setup and you will love it..
Hotrodboba400
Dec 10, 2019 07:07 PM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
