Transmission Change
Old Mar 5, 2012 | 05:25 PM
AJ Mc's Avatar
Car: 1984 Camaro Z28
Engine: 5.0L 305 High Output
Transmission: Automatic 700-R4
Transmission Change
So it is clear that there are many differing views on changing the Transmission fluid and filter on a vehicle that has not had regular maintenance. Some feel it is safe to go ahead and change it, some feel that the new fluid might loosen up debris and cause major problems.
Here is what I propose...
What if I were to drain the fluid, not flush it out, simply drain it. then change the filter. then put the old fluid back in (excluding of course any large debris or perhaps after a straining).
This way there would be no new detergent in the fluid and I could have a brand new filter.
Old Mar 5, 2012 | 06:55 PM
19camaro83's Avatar
Car: 1983 camaro sport coupe
Engine: 2.8l v6 - stock motor
Transmission: NWC t-5
Axle/Gears: whatever came stock (?)
Re: Transmission Change
It's your car, do whatever you feel is right
Personally, I have never had any issues by draining the pan and torque converter and refilling with recommended fluid on any of my vehicles.
Old Mar 5, 2012 | 06:59 PM
AJ Mc's Avatar
But I'm sure you change the filter at regular intervals. there are several discussions on here about the risks of changing after not changing it for a long time. then again some are lucky and dont have any problems even if they have never changed it.
My concern is that I have a vehicle with over a 100k miles on it and I have no record of any service. I fear putting in new fluid can loosen up debris and cause some serious problems
Old Mar 5, 2012 | 07:10 PM
19camaro83's Avatar
Nope, haven't owned anything long enough to make regular changes (usually 30k mile intervals). Any vehicle I have owned has had over 100k miles on it, and who knows if it was ever serviced.
Old Mar 6, 2012 | 10:58 AM
torque_is_good's Avatar
hogwash
change the fluid and filter
if your tranny has issues then they existed already
Old Mar 6, 2012 | 12:33 PM
AJ Mc's Avatar
I understand how you feel torque, but if you read other threads you will see that many believe that this gunk is the glue holding the car together. yes my tranny might already have issues, but i dont want to aggravate or rush them along.
I simply want to know how ridiculous it sounds to reuse the tranny fluid to avoid adding too many detergents
Old Mar 6, 2012 | 12:57 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
i can tell you from experience,...if the fluid is brown and stinks like its burnt real bad, dont change it. just a waste of money and its gonna make the tranny worse. i agree, if its that bad you have issues of course. my bud has a used car lot and ive seen it first hand a few times. car runs fine, change fluid and it starts slipping. obviosley these were trannys ready to take a dump anyway. again though, this was really brownish fluid and has a burnt smell. i use type-f in all my g.m. automatics. i believe it to be the best fluid, with the most anti-foaming agents. been useing it for 20-25 years. b and m recommends type-f if not useing theyre trick shift fluid. jmo.
Old Mar 6, 2012 | 03:58 PM
if you wish to believe the myth then don't touch it, seriously. If it's already slipping then it's too late.
Every single used car I've ever purchased I flush all the fluids including brake. I've been doing that probably longer than most here have been alive.
Old Mar 6, 2012 | 06:50 PM
19camaro83's Avatar
Like I said, it's your car, do whatever you feel is right...
Old Mar 6, 2012 | 07:10 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Even though I do my own maint. when it came to my transmission I went to Quick Lube and had them put it on the machine that filters all the old fluid out and puts new fluid in and then they install a new filter. This is just what I do.
Old Mar 6, 2012 | 08:34 PM
19camaro83's Avatar
Watch this link
http://www.youtube.com/watch?v=LTJjqr0QbIk
Old Mar 6, 2012 | 08:42 PM
AJ Mc's Avatar
haha part of the reason I like to do as much work myself as I can
Old Mar 7, 2012 | 12:38 AM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Everyone should add an external filter like the oil filter with a magnet stuck on the bottom of the filter. The filter in the pan is OK but not nearly as good as a mobil one filter plumbed in-line along with a cooler.
AussiePr0nCar
Mar 6, 2020 04:04 PM
midge54
Dec 27, 2019 04:14 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
Trickskier
Aug 29, 2015 01:12 PM
