No More Posi Action
Old Mar 7, 2012 | 08:09 PM
akanitro's Avatar
Car: 1989 GTA, 2004 Z06, 2008 Expedition
Engine: L98, LS3, 5.4L
Transmission: 700R4, MN6, Auto
Axle/Gears: 3.23, 3.42, ?
No More Posi Action
Just curious if anyone else on here has experienced the clutches wearing out in their 9 bolt differential? I need to rebuild it or if anyone has any other ideas and/or concepts of other rear ends to swap with, I am up for suggestions. I can't do the 1 wheel peel.
Old Mar 7, 2012 | 08:11 PM
LsxMatt's Avatar
Car: 86 Sport Coupe
Engine: 5.3 LM7
Axle/Gears: 4th gen 3.42 posi
Re: No More Posi Action
If your looking for a rebuild i have a nice set of 9 bolt posi cones im looking to sell.
Old Mar 7, 2012 | 08:30 PM
akanitro's Avatar
I might be interested. I have never built one of these diffs before but it should be similar to the 10 bolt I am guessing. What are you asking and is there anything else I would need? The rear is not whining and no leaks or anything.
Old Mar 7, 2012 | 08:45 PM
LsxMatt's Avatar
Car: 86 Sport Coupe
Engine: 5.3 LM7
If there are no other issues, you should be alright with the cones. If possible, you should pull the rear apart before getting the new cones, just to be sure the carrier is alright. I can give you both cones for 75.00 shipped
Old Mar 7, 2012 | 08:50 PM
akanitro's Avatar
I will check it out this weekend after work and let you know. Thanks for the info and advise.
Old Mar 7, 2012 | 10:13 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Those are used factory cones. You can buy new ones, but you'll ahve to have machine work done to either the cones or the carrier to accomodate them. Those used factory ones are a good deal if they're not worn.
You got any pictures of them in the carrier to show how far they are from bottoming out?
KO1
16
Oct 15, 2015 05:00 PM
mfp189
Sep 27, 2015 09:25 AM
