Torque converter bushing and seal ?
Old Mar 19, 2012 | 07:14 PM
GeeJenn91RSV8's Avatar
Car: 1991 Camaro RS
Transmission: 700 R4
What's up. Two questions for you guys. I just pulled the 700r4 out of my 91 camaro to replace the front seal. First question is what happens to this seal that causes it to leak. The one that I pulled from the tranny looked ok to me but I have no doubt that it was leaking. I pulled the converter cover off and when I would start the car it would fling fluid everywhere plus when I would turn the car off you could see the fluid running down the back side of the converter. Second question is that i read on hear.... while the tanny is out to check the bushing and see if it is worn. What exactly am I looking for in a worn bushing? Nothing looks worn to me and I really don't want to go any deeper in this trans than I have to. Thanks
Old Mar 20, 2012 | 05:58 PM
Car: 1991 Camaro RS
Re: Torque converter bushing and seal ?
Anybody?
Old Mar 22, 2012 | 12:46 AM
cliffharris's Avatar
Car: 1986 Corvette
Engine: 5.7 liter
Axle/Gears: 3.07
There is a "drain back" hole behind the seal that gets overwhelmed with too much oil so it has to go somewhere and it goes around the seal. Enlarging the drain back hole is pretty standard with high performance rebuilds.
Your pump shouldn't need to have the front bushing staked because GM added a lip for the bushing to seat against in the late '80s.
Here's an article on 700r4 pump modifications:
http://www.crankshaftcoalition.com/w..._modifications
Old Mar 22, 2012 | 01:46 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Remove the pump and replace the pump bushing&seal and look at the torque converter hub.
1992 Trans Am
May 10, 2023 07:19 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
xxx3man`
Sep 23, 2015 10:37 PM
gwade12
Aug 8, 2015 08:17 AM
