speedo cable P/N
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
speedo cable P/N
What's the speedo cable that goes to the trans to the engine bay I keep getting the 1 to the speedmeter to engine bay the trans is a 30 spline 700r4 my broke in the trans and its leaking a little
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: speedo cable P/N
JamesC
Car: `86 SS / `87 SS
When I looked up PN for a few different GM vehicles years ago, I found the two-piece non-transducer application cables tended to be installed on cars with higher (3.73, 3.42) gear ratios. But the lower geared models (2.14, 2.29, 2.41, 2.56, 2.73) tended to be listed as using the single-piece cables.
I've also had poor results from swapping a new GM one-piece cable into a car that originally had a two-piece cable and 3.73 gears. I pulled that later and installed a used two-piece cable with over 150k miles with better speedometer stability.
Sometimes it's easier for drivelines to be done as 2-piece from a manufacturer perspective and that may apply to speedometer cables as well.
In an indirect manner, I found Napa's cable listed for your car is indicated to be two-piece. Hope it works out for you.
My car came with cruise control I will try to take pics of what I'm taing about
If a cable goes into a transducer (located on the driver's side more or less under the wiper fluid tank) and another exits, I'd be surprised as, IIRC, that configuration ended early on--my 85, at least, isn't so equipped.
JamesC
JamesC
Z28/ZR1
Oct 23, 2015 01:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
